Vacuum Leak Smoke Test Point
On my 87 3.2, Where are the best points to do a vacuum smoke test?
lake wales fla
If you have cruise control connect the hose from smoke machine to the vacuum port for the cruise servo where it connects to the power brake hose.
Richard |
I also want to run a smoke test on my '87. What is the best method to close off the intake path? Does the air filter box need to come off? Thanks.
