Valve Cover Stud Mystery
I’m about to do a valve adjustment on my 3.2 and a couple of studs came out while I was removing the lower valve covers. While putting them back in, I noticed that one stud did not match all of the others. The stud in question has an elongated (non-threaded) center, with each of the threaded ends about the same size. All of the other studs have a smaller non-threaded center with long threads in one end and short threads on the other (see comparison photo, attached). What gives? Is this a case of Porsche engineering gone wild or a screw up by the last guy who adjusted the valves? Thx.
Someone has replaced a stud - with an off the shelf generic stud. No issues as long as it all matches up OK for thread engagement etc.
Given they were loose anyway - one may have fallen out at some time. Who knows? Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
PCA Member since 1988
They're the same length. Don't worry about it. No one but you will know.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Thanks - much appreciated.
The 9 Store
50+ year old cars. Lots of people have touched these cars and have done all kinds of “fixes”.
All used parts sold as is. |
