-   -   Dash lighting fuse installation (http://forums.pelicanparts.com/porsche-911-technical-forum/105819-dash-lighting-fuse-installation.html)
GeorgeK 04-09-2003 01:45 PM
I have installed a fuse to protect the dash lighting. The whole circuit that lights the counters, the heating controls, the electronic heating central between the seats, the switches for the rear defrost, the fog lights is not fused. I was afraid that a short there would cause extensive damage.
So for the general info, here a pictorial:
First, REMOVE the driver's seat. You'll thank me later, when your back does *not* kill you:
http://forums.pelicanparts.com/uploads/930dash01s.jpg
You can then easily rest on your back to look at the back of the headlight switch under the dash:
http://forums.pelicanparts.com/uploads/930dash04s.jpg
On that switch, identify the post 58A, it should have a lot of black/blue wires attached to it:
http://forums.pelicanparts.com/uploads/930dash05s.jpg
This is where the fuse will go. I bought a fuse holder and some 3A fuses:
http://forums.pelicanparts.com/uploads/930dash03s.jpg
A few crimps, welds, and shrink tube applications later:
http://forums.pelicanparts.com/uploads/930dash02s.jpg
All that is left is to put the fuse holder between the connection 58A and the black/blue wire bundle:
http://forums.pelicanparts.com/uploads/930dash08s.jpg
Tried, and it works. Not bad for a self confessed electrical moron (I actually understand quite quickly if you explain long enough).
GeorgeK
Wil Ferch 04-10-2003 01:24 PM
GeorgeK:
Nice job...
Just curious. When you say "It works"...do you mean the dash lights work with a fuse installed..and are "out" when the fuse is pulled ??
---Wil Ferch
GeorgeK 04-10-2003 01:34 PM
Yes, that's it. Removing the fuse takes all the dash lighting out.
Actually, when I saw that the car did not catch fire right after an electrical modification of mine, I was quite relieved.
GeorgeK
Wil Ferch 04-10-2003 01:45 PM
GeorgeK:
One more thing GeorgeK...
This seems to be a jump-off from another thread, and you now confirmed ( thank you) pin # 58A. Steve Grosskemper from San Diego (?) region PCA first wrote this up in a tech article...but the pin number he used was incorrect, or was usable only for an earlier range of cars. Digging further, it appears from a review of my 85 Carrera wiring schematic, that such a fuse might only protect dashlights, but I thought it didn't protect fresh air blower area lighting ( two sources of power) and the climate control knob in the console. Can you confirm which car you did this on ( 76 or 83, as the pin # might be different)...and when you pull the fuse...what it all protects ??
---Wil Ferch
keitho64 04-10-2003 01:50 PM
I did the same thing on my 69 except I used a circuit breaker from AutoZone. I did this while I was troubleshooting a short that turned out to be a bad fuel gauge. I just left the breaker on the circuit. On the 69 the dash is powered off pin 15 of the ignition switch. I installed the breaker after the switch and prior to the gauges then tucked it under the dash.
GeorgeK 04-10-2003 02:17 PM
On this car ('83 930), the fuse protects all gauges, the heating/ventilation command, the fog and rear defrost switch lighting, the thermostatic command's lighting (between the seats). The ashtray lights is not covered by this fuse.
To be absolutely precise, I did *not* manage to look at the name of the terminal to which the lighting wires were attached (very little room there). I consulted the wiring schematics for the year 1983, and that indicated terminal 58A, and the black/blue wires.
What I *did* check was that the black/blue wires were the current for the dash et al lighting, and that once the fuse was in line, removing it cut the lighting, without affecting other electrical functions.
GeorgeK
GeorgeK 04-10-2003 02:22 PM
I now checked the wiring diagram for the '77 Carrera and on that car too, the terminal 58A is the one feeding the dash lighting, and the heating panels. Can't check on my '76, it's still in the showroom waiting for an engine.
GeorgeK
Randy Webb 04-10-2003 04:39 PM
It's a very clean installation. Would it be better to fuse the wire run earlier in the circuit -- closer to the batter? Where does the unfused wire originate anyway?
And does anybody know what you'd do on a '73?
GeorgeK 04-11-2003 03:23 AM
Randy,
the other circuits coming off the switch are fused, only the dash lighting isn't. No use putting a fuse earlier in the path. Here the unfused circuit originates at the 58A terminal of the switch
GeorgeK
Randy Webb 04-11-2003 10:38 AM
I'm confused... So technically the wire is fused but the fuse is such a high value that it won't blow if the wire gets accidently grounded?? Is that it?
keitho64 04-11-2003 11:02 AM
Randy
In my case this fuse also powered the ignition circuit. When my fuel gauge died and caused the fues to blow, it killed power to the entire car. Hence I was left stranded. This was my reasoning for splitting the circuit in my car and adding the breaker. Keep in mind mine is a 69 and I do not know how different it is.
GeorgeK 04-11-2003 01:20 PM
Randy , Here is the way I understand it:
Battery+--->Switch--->different circuits commanded by the switch, all of which ARE fused, except the one that brings current to light the dash. Hence the recommended installation.
GeorgeK
RoninLB 04-11-2003 01:39 PM
this project is a home run.. the pics relax the beginner.. the lugg. comp light is also on this circut.. solder the wires to the connector.. without the fuse it's a fire waiting to happen/maybe.. George used the proper 3amp fuse..
I've been insisting that my brother do this install on his'88.. his mechanic said he never heard of this install.
you gotta love Pelican.........
Glasgow 911SC 04-11-2003 02:02 PM
So this & the headlight relay are the reccommended electrical updates?!
GeorgeK 04-11-2003 02:11 PM
Yes, they are the 2 most "dangerous" electrical places in the car.
For the 930 owners, there is another, more bothersome than dangerous: The second fuel pump, in front of the LR wheel is wire in series with the first under the tank, which loads the relay. Often in hot summer days, the relay gives up, stranding the car. The solution there is to rewire the 2nd fuel pump from the same command, with another relay and new wires.
But this only goes for cars with 2 fuel pumps (930 up to 1989, and maybe more modern ones?)
GeorgeK
RoninLB 04-11-2003 02:21 PM
Chris.. I don't know what they recommend.. IMO, the 911 wireing sucks... I wouldn't be alarmed if some circuts would only blow a fuse.. but when they are the reason that my 911 is burnt toast, that scares me..
and "the headlight relay" project... one is better than nothing, again to prevent toasted circuts.. 4 is the safest, IMO.. I use 2 75amp relays and new wires on big bulbs.. and another back-up ground strap from the starter case mounting bolt to the drivers tranny mount bolt is not a bad idea.. I got a pic of that if you want to cast the eyeball..
it's great that you take this stuff seriously.. and the projects are easy to do.. and it's a clean finger nail job................Ron
Glasgow 911SC 04-11-2003 03:30 PM
"it's great that you take this stuff seriously.. "
I guess you have to- no brainer.
I have noticed how hot a yellow wire at the back of the light switch gets when turned on. Can't be good!
Thanks for the info guys!
RoninLB 04-11-2003 03:34 PM
the circut was designed years ago when stock bulbs were less than 65/55w.. and had never been upgraded.......Ron
Randy Webb 04-11-2003 04:29 PM
"Randy , Here is the way I understand it:
Battery+--->Switch--->different circuits commanded by the switch, all of which ARE fused, except the one that brings current to light the dash."
- Yow! There's awire that runs all the way to the switch w/o going thru the fuse box? Who designed this thing? Excellence was Expected but Not Always Achieved.
Wil Ferch 04-11-2003 06:41 PM
Glascow:
There are many more electrical areas..Porsche does a really poor job in this category.
- For A/c cars....add the 7.5A fuse kit for the front condenser fan. Another fire hazard.
- add headlight relays, as mentioned
- add upgraded relay with external 16A fuse in smugglers box ( A/c system)...late 70's to late 80's cars.
- oddly *all* relays that Porsche uses ( ex: foglight relay) is fused only on the power side...not on the control side. Quick wire switcheroo will fix this.
- fuse box disaster. Design uses riveted construction of fuse holders that may get loose over the years. At some point in time, take box out, re-tighten or solder the rivet connections. Some of these have "bus-bar" connections that jumper incoming points on the fusebox. Or use external wire jumpers. Best to add external wire jumpers *everywhere* there is a bus connection with no external jumper wire to begin with. This would end up being a duplicate, parallel circuit.
- 930 A/c system gangs too many loads into too few circuits. Steve Grosskemper ( again) ....or was it John Rice..offers suggestions on how to add more fuses to separate these loads and have the wires run cooler. I think this article resides somewhere in the Pelican Tech Article section.
- no headlight relays ( as mentioned)
- other interior lights are still not fused with this mod ( cig lighter...fresh air panel).
I could go on....but I'm getting ill again thinking about all this...and all the work ahead of me to remedy these "excellence expected but not achieved" designs. What did Porsche do?..hire apprentice electrical designers??
- Wil Ferch
Paul Thomas 04-11-2003 09:16 PM
George,
Maybe i'm the only one that hasn't seen it before, but that color combo on your car in FANTASTIC! I can't get over the green. I love it.
Paul
GeorgeK 04-11-2003 11:03 PM
Will,
"other interior lights are still not fused with this mod ( cig lighter...fresh air panel)."
Yes they are, at least on this '83 930. The fog and rear defrost switch lighting, the heater/ventilation panel, and the thermostatioc command lighting between the seats are lighted through this new fuse. The ashtray isn't.
Paul, Thanks, It's "ziegelrot metallic" (brick red), with olive leather interior:
http://forums.pelicanparts.com/uploads/DSC02379s.JPG
GeorgeK
Wil Ferch 04-12-2003 04:22 PM
GeorgeK:
Thanks..if it indeed protects all of those items, that would be great. The wiring diagrams for my 85 suggest that they aren't..so I'll check how the 83 and 85 compare...maybe I'm reading these things the wrong way. Thanks for documenting this.
---Wil Ferch
Glasgow 911SC 04-14-2003 06:33 AM
Yikes.......I'll be having nightmares now!
Wil Ferch 05-07-2003 11:19 AM
George:
I'd like to prefab the fuse holder ends like you did.
Did you end up with one female spade end and one male spade end on the fuse holder?
What size spades did you choose?
It looks like there are three black/violet wires ganged to post 58A. Are these ganged together on one spade in the original wiring harness?
--Wil Ferch
GeorgeK 05-07-2003 12:59 PM
Hi Will,
Yes I put one male and one female spade connectors on the fuse holder.
The black/blue wires are "piggybacked" together on the 58 terminal. There are 3 spades for 4 wires with a male coming out of the female connector, next to it.
The spades are the same size the factory uses, I think 6.3 mm.
GeorgeK
Wil Ferch 08-02-2003 07:09 AM
Guys:
I'd like to reopen this thread with two questions:
1.) I fabbed a fuse set up like George's , but am using the "mini" ATO style fuses. Is this a mistake from an availability standpoint..or are more cars going this way which might make it more available?
2.) I also found ( in this small size) ...a 2A version instead of 3A. Always looking to avoid electrical problems, I'd like to go as low amp rating as possible. Would these work or would they give nuisance trips?
---Wil Ferch
RoninLB 08-02-2003 09:48 AM
I can understand taking the fuse seriously.. tooo seriously for me but..
do a current check of the circuit and the max current should be 70% of the fuse .. my luggage comp. lite is also on that circuit.. I don't know about engine comp lite......
Bill Verburg 08-02-2003 10:11 AM
Good idea George!, Now I have yet another project.
In the same vein, I find that I am getting quite a collection of add ons to the battery (+) & (-) terminals, currently DME and 2 audio wires. Since I am in the middle of adding another 2 for the headlight relays, my thought was to add an auxillary 6 terminal fuse block. I have seen the Anchor ones and they are very nice.. Anyone do a similar install.
RoninLB, My thought was to use 2 x 40A relays for the high and 1 x 40A relay for the lows, there is plenty of safety margin w/ this setup. What's the advantage of 4 relays?
Wil Ferch 08-02-2003 10:40 AM
Bill:
Look at the Pelican Tech Articles ( right here !) and you wil find some electrical articles by a Mr Rice talking about add-on ( OEM style) fuse blocks to unload the 930's A/C circuit somewhat. Not quite what you had in mind but close.
I would guess the advantage of 4 relays is that you'd only have any *one* light fail and retain lighting for any remaining three options ( left low--left hi--right lo---right hi). How 'bout using Bosch cube style 50A relays , with silver contacts and X million cycle life from Wayek ( www.waytekwire.com I believe)
Ahhh....ummmm... how 'bout my question? ( availability of smaller size ATO style fuses... and has someone else done a current draw check to see if 2A vs 3A is better?) I know we're scratching on small differences, but on a % basis, 3A vs 2A *is* a big deal !
---Wil
Bill Verburg 08-02-2003 11:01 AM
Thanks Will but I didn't find that article particularly informative. I know how to wire, just looking for experience w/ hardware. In addition I don't want factory style fuses. Ideally a circuit breaker type of fuse block can be installed. If not at least some modern fuses.
I guess I'll try to cruise some audio enthusiast sites for other ideas.
I have one of Marcus Sucro's kits, which is very nice and will be modified to do the high beam only(2x40A relay). I'll probably buy another kit and then have a spare relay, hence my ? for RoninLB.
RoninLB 08-02-2003 11:34 AM
Hey Bill..
I don't want to come off as neurotic.. but Blue Sea Systems has a magnetic 8 breaker board that I mounted on the floor. next to the battery.. and the style of tripping is vastly superior to fuses.. so it's not affected by ambiant heat.. and the wireing is screw fastened/ no clamp fastening.. and I use two 75amp Bosch relays because it has bigger contacts and it's also screw fastened.. I have the Bosch # close by if needed.. anyway one 75amp relay for both highs, and one for both lows.. and like Wil said 4 relays is safer.. if I trip my lows then I burn retinas till I reset. and the Bosch is mounted on the inside front bulkhead, tucked under the lip with threaded rivets.............
RoninLB 08-02-2003 11:51 AM
Bosch 75 amp
part# 0.332.002.150
http://forums.pelicanparts.com/uploa...1059850292.jpg http://forums.pelicanparts.com/uploa...1059850308.jpg
Bill Verburg 08-02-2003 12:53 PM
The Blue Sea systems 30 x 6 w/ separate ground is the one 'm looking at. You're happy I take it?
The 8 sound even better, any pics?
On the 75A Bosch are those spade connectors for the contral circuit in the corner?
RoninLB 08-02-2003 03:07 PM
"The Blue Sea systems 30 x 6 w/ separate ground is the one 'm looking at. You're happy I take it?"
http://www.pelicanparts.com/support/smileys/boldblue.gif[/img]
"On the 75A Bosch are those spade connectors for the contral circuit in the corner?"
Yep
http://forums.pelicanparts.com/uploa...1059862041.jpg
http://forums.pelicanparts.com/uploa...1059862061.jpg
Bill Verburg 08-03-2003 12:47 PM
Thanks!
Oracle 08-03-2003 01:48 PM
Excellent project and very clear pictures!
Today I followed your suggestion and now I feel more relaxed that no accidents will burn the dash wiring....
In my case the post #58A has just 1 black/blue wire but when the just installed fuse is out the dash lights do not turn on, so at least that area is now covered....
Thanks!
-J
Randy Webb 08-03-2003 05:31 PM
Wouldn't it be better to put a fuse in closer to the battery?
RoninLB 08-03-2003 07:06 PM
the headlight sw. gets power from the ignition sw... and may branches from the light sw. run to the fuse panel, then to the various lights.. but not the dash lights, which should include the luggage comp. light and engine compartment light, etc... I used a small 3 amp marine resettable circuit breaker instead of an inline fuse to eliminate another contact/ whatever.................
Wil Ferch 08-04-2003 09:22 AM
OK...before this thread was "hijacked" :) .....let me go back to one reason I re-opened this topic:
--- are the "smaller" ATO type fuses a mistake to use with regard to easily finding spares? Are they becoming more common, in general, or less so? ----
Wil
