Pedal cluster, what and how to lube
1988 3.2, I removed the driver side wooden floorboard to clean up behind there and it was pretty clean and wonderfully dry. What should I lube while I am in there and what is the best grease for the linkages? I seem to remember something about synthetic grease because of composite bushing?
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 04-20-2020, 08:42 AM
daddygo's Avatar
Lubrication
There's some detail on other posts about lubrication of the pedal cluster, just search for pedal cluster. As for the other linkages I'm sure a little 3 in 1 oil won't hurt, just don't over do it because the dirt and dust find it fast.
I just re-bushed my pedal cluster... now shifts like butter, compared to the crunchy, hard clutch I used to deal with. While I was in there, I noticed the master cylinder leaking (every primary project seems to uncover one or more sub projects), so I replaced that as well. Turned my two day project into a four day project.
Good luck!
1973 911T Targa ROW
Old 04-20-2020, 05:45 PM
Under the radar
Trackrash's Avatar
Do you still have the original plastic bushings in the pedals? If so, I would squirt some silicone spray lube there and hope for the best.
If they have been upgraded to the bronze bushings just use some motor oil.
Those plastic bushings are known to suddenly and without warning disintegrate. AHIK.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-20-2020, 06:11 PM
