The heater blower doesn’t sound right
So I got in the car (1988 911 coupe) today, and not heat. I checked the fuses in the panel in the engine compartment and the blower motor one (the one in the engine compartment) had popped. I replaced it, and now when I pull the red levers in between the seats it comes on, but sounds more like an inconsistent humming sound than the sound of a fan turning on. The fuse hasn’t popped again. I’m guessing the blower motor has started to seize up or something. Anyway, I just wanted to see if anyone else had a similar issue, and had any suggestions for possibly repairing the motor. I understand you can buy just the motor and not the whole unit including the housing.
Old 04-19-2020, 10:08 AM
This is the sound
https://m.youtube.com/watch?v=aXcKT5hXFFE&feature=youtu.be
Old 04-19-2020, 10:32 AM
MichaelSJackson's Avatar
Sounds like a leaf got sucked in? Sort of like using a clothes pin to attach playing cards to your bicycle wheel.
Old 04-19-2020, 11:46 AM
carreradpt's Avatar
It's easy to pull the heater blower motor and bench test. Lots of threads on this.
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 04-19-2020, 12:20 PM
The heater motor is really in two parts spot welded together. Mine was making lots of noise. I took the unit out and the two parts were loose making the fan scrap the inside. I used JB Weld , put together and fan is quiet as a mouse!!!
Old 04-19-2020, 04:21 PM
