-   -   Is a fuse "bus" the same as a jump wire? (http://forums.pelicanparts.com/porsche-911-technical-forum/1058579-fuse-bus-same-jump-wire.html)
djcdmv 04-20-2020 09:09 AM
So I'm having power window problems and determined that the rivet holding the bus of the first two fuses has come loose. Is a jump wire between fuse 1 and fuse 2 the same as the bus that is behind the fuse block? Thanks in advance!
timmy2 04-20-2020 09:49 AM
Yes, a jumper wire will fix the bad rivet problem.
Might want to look at the replacement ATO style fuse panels Pelican lists for the future.
HaroldMHedge 04-20-2020 06:29 PM
Connecting Rail
You could also use a Connecting Rail 901-612-835-01. These were used by the factory to jump between two fuses.
