Brake question
Hi all, I am thinking about going with bigger front and rear caliper and rotors. Can anyone steer me in the direction what I should be looking for. Mine is a 1969E. Is there other years of Porsche that will fit if I find rotor, Caliper and brackets.
1969 911, resurrected into Widebody Slantnose Cabriolet
Old 08-28-2024, 06:30 PM
PCA Member since 1988
If you have not increased the power of the engine substantially, you don't need bigger brakes, especially if you primarily drive it on the street. That said, there are several recent threads about upgrading brakes that will give you some ideas of what you might do.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-29-2024, 12:15 AM
H-viken's Avatar
Tons of threads on this. Find Bill Verburg’s profile and see which threads he has responded to, he is in most of the relevant ones
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 08-29-2024, 01:36 AM
check out this thread https://forums.pelicanparts.com/porsche-911-technical-forum/904694-brake-upgrades-early-911-help-please.html
Old 08-29-2024, 07:02 AM
Look at the Alfa Brembo thread over on Early911sRegistry.org. I put Boxsters on my 67. Have a friend looking for calipers for a 73.5. Easily doable with some cash.
Old 08-29-2024, 07:08 AM
