-   -   Carrera front hub/rotor bolt circle question (http://forums.pelicanparts.com/porsche-911-technical-forum/1058732-carrera-front-hub-rotor-bolt-circle-question.html)
wjdunham 04-21-2020 04:33 PM
Can someone confirm that the bolt circle for the bolts that mount the hub to the rotor are on a 126mm circle. I believe I found this on a spec. sheet somewhere but can't dig it up and want to make double sure. I am having some custom rotor hats made so measure three times cut once.
For extra credit, what is the bolt hole size?
Thanks in advance as always,
Bill
pete3799 04-21-2020 05:03 PM
130mm according to this
https://www.wheel-size.com/size/porsche/911/1969/
Joe Bob 04-21-2020 07:15 PM
5x130, our host carries the correct nuts. I prefer open top steel as opposed to the alloy nuts.
The alloy ones tend to fracture and you a hell of time getting the remainder off w/o fubaring the wheel. AND FOR GOD's sake don't use wheel locks.
wjdunham 04-21-2020 07:24 PM
Sorry, I didn't mean the bolt circle for the wheel bolts, which is indeed 5 x 130mm, but the bolt circle for the bolts in the inside of the hub that mount to the brake rotor.
Bill
Joe Bob 04-21-2020 07:28 PM
Maybe if you told us what is up? Did you lose them? You could always pull annother wheel and remove the bolt in question and measure it.
wjdunham 04-21-2020 08:30 PM
I'm putting together a rotor setup for my 964 caliper upgrade. I plan to share that all in a build thread once i get farther along. I'm having a custom flat hat fabricated, and using a Coleman Racing custom sized rotor. Here is the drawing for the rotor hat. I want to make sure the inner bolt circle is the correct dimension.
Bill
http://forums.pelicanparts.com/uploa...1587526026.jpg
donporfi 04-22-2020 10:08 AM
I measured this hub. Rough measurement.
That bolt circle is 126mm.
Between centers 74mm, that gives us 126mm diameter.
http://forums.pelicanparts.com/uploa...1587575199.jpg
donporfi 04-22-2020 12:41 PM
It uses 8 x 22 hex head bolts
wjdunham 04-22-2020 01:00 PM
Thanks!!! That's what I needed.
Bill
