Determining wheel size
I have a set of 15" wheels on my 83' SC. I believe they are 7's & 8's. How can I confirm that I am correct on that assumption?
Measure them..... |
if they're fuchs, they should have Porsche part numbers (and size markings) on the insides of the spokes -- other wheels (even aftermarket) should have similar markings -- pull a front and rear wheel and look what they show from the inside
If they are Fuchs http://forums.pelicanparts.com/uploa...1587591628.jpg http://forums.pelicanparts.com/uploa...1587590901.jpg measure if not this is a 7 http://forums.pelicanparts.com/uploa...1587590982.jpg this is a 6 http://forums.pelicanparts.com/uploa...1587590982.jpg wheels are defined by the bead width not overall width http://forums.pelicanparts.com/uploa...1587590982.jpg If tires are mounted use rubber bands to hold 2 laths that rest on the wheel flanges, measure the distance between laths and then subtract the width of the 2 flanges, for Fuchs you would subtract .7, most modern wheels have .5" flanges so subtract 1", BBS is an exception subtract .8 http://forums.pelicanparts.com/uploa...1587590982.jpg |
| All times are GMT -8. The time now is 10:43 AM. |
