Lash
Unable to use Magna Weld dent puller
I'm trying to pull a small dent out of the bottom pan near the front torsion bar. I removed the under coating and used wire brush to make sure I have a clean metal surface. Using an Eastwood Magna Spot Weld dent puller I was unable to weld a pin to the clean metal. I'm able to weld scrap sheet metal so I know the spot weld unit is working like it should. I see when I push the welder up against the spot it makes a few small sparks like I have a dirty surface and not making good electrical contact. The spot is super clean.
Does this problem I'm having anything to do with Porsche and galvanizing sheet metal for rust protection? I have a 1980 SC. Thanks Lash |
Mmmm, could be, eh?
Lash
Maybe sand down to shiny metal in a couple of places and retry? That's what I'd do. I have a similar machine and find it easy to use. Best of luck, John
Lash
OK
I fixed the problem, used air sander on dent and Emory cloth on Magna Spot welder and I was able to weld pins to the dent. One of those days, and now its after 5 o'clock here. Lash |
Good for you. It is too simple a circuit not to work. Good ground and good clean surface for the pin.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Yep. Good ground connection nearby. In addition, disconnect battery less you fry some electronics.
Maybe the galvanized chassis coating was giving you problems, needed to grind down to fresh metal.
Current: 1975 911S --Chocolate brown Past: 1967 911S --Bahama Yellow 1990 C2 Targa --Silver 1973 914 2.0 --Delphi Green |
Lash
I make it a rule to always disconnect the battery when working on cars. Thanks everyone for your input. Lash |
