cycling has-been
Rear brake rotor compatibly; 65-68 911 vs 912E
Looking for help as to whether or not the rear solid rotors from the 65-68 911 will work on my 1976 912 E.
The reason being, I found someone who sells drilled units, and that's what I want: Please don't turn this into a forum on pros and cons of drilled rotors. Thanks in advance Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
cycling has-been
cycling has-been
Bump
Paging Bill V ??
I went in to the Pelican catalog, looked up a rear rotor for both a 912E and a 68 911 and they were the same part number so knowing that I would say yes you could use that drilled rotor.
cycling has-been
Thanks Ryan.
That part on the second page of the illustration scared me - all the fitments go into a Ford F-150. ![]() Bill K
cycling has-been
Update: The definitive answer:
I took a chance, and ordered the rotors from ********* on Ebay. They would not work without modifications to the mounting ears on the trailing arm. The main difference is the depth of the e-brake hat. The hat on the 912E rotor is over 1/4 inch deeper (higher). Using the new rotor this would bring the rotor 1/4 inch further away from the hub. I was not up to dealing with this via spacers, and bending the lines. The good news is that the vendor issued me a pre-paid FedEx label for the return, no questions asked. Bill K
