Lash
Unable to use Magna Weld dent puller
I'm trying to pull a small dent out of the bottom pan near the front torsion bar. I removed the under coating and used wire brush to make sure I have a clean metal surface. Using an Eastwood Magna Spot Weld dent puller I was unable to weld a pin to the clean metal. I'm able to weld scrap sheet metal so I know the spot weld unit is working like it should. I see when I push the welder up against the spot it makes a few small sparks like I have a dirty surface and not making good electrical contact. The spot is super clean.
Does this problem I'm having anything to do with Porsche and galvanizing sheet metal for rust protection? I have a 1980 SC.
Lash
Old 04-23-2020, 02:04 PM
Mmmm, could be, eh?
206 637 4071
Old 04-23-2020, 02:43 PM
Lash
Originally Posted by john walker's workshop View Post
Mmmm, could be, eh?
I have successfully welded pull pins many times, many different cars.
Today I have test welded pins to four different pieces of scrap metal.
I hope someone else can shed some light on this problem.
Lash
Old 04-23-2020, 02:58 PM
Maybe sand down to shiny metal in a couple of places and retry? That's what I'd do. I have a similar machine and find it easy to use. Best of luck, John
Old 04-23-2020, 03:05 PM
Lash
OK
I fixed the problem, used air sander on dent and Emory cloth on Magna Spot welder and I was able to weld pins to the dent.
One of those days, and now its after 5 o'clock here.
Lash
Old 04-23-2020, 03:18 PM
Originally Posted by kltarga72 View Post
OK
Lash
Good for you. It is too simple a circuit not to work. Good ground and good clean surface for the pin.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 04-23-2020, 04:23 PM
Yep. Good ground connection nearby. In addition, disconnect battery less you fry some electronics.
Old 04-23-2020, 05:56 PM
Maybe the galvanized chassis coating was giving you problems, needed to grind down to fresh metal.
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 04-23-2020, 06:21 PM
Lash
I had used a wire wheel to remove the undercoating and I had what I thought was a clean metal surface. Only after using air sander to further clean the dent was I able to weld the pull pins. Possibly there was some type of coating that did not allow a good electrical contact.
I make it a rule to always disconnect the battery when working on cars.
Thanks everyone for your input.
Lash
Old 04-23-2020, 07:39 PM
