still..way too much space...plus when you touch the cable is the Omega spring have the tendency to move -it does not look like it??..there is no tension on the cable at all....have a look above-earlier, how i do the adjustment..
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 04-27-2020 at 11:32 AM.. |
I've got an extra L bracket. If you get stuck we can work something out.
1978 SC Targa |
I'm sure this was already addressed, but are your doing the two stage adjustment?
Step one with the cable slackened or un-hooked - ![]() Step two, re-attach and pre-load the cable -
1978 SC Targa |
I thought the video I posted above looked proper, but Ivan disagrees.
i have never done clutch adjustment by reading books ,sorry;-) i just go by what i know and what i learned from my mentor, back in the early 1980......we did not have the time to read we just worked together, sometimes overnight on engines so he passed the knowledge to me by working on 911`s
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 04-27-2020 at 12:32 PM.. |
This is the "$5 part" that your mechanic was probably referring to. It attaches the clutch cable to the clutch pedal cross shaft - ![]() Which chewed up my pedal cross shaft which led me to completely rebuild the pedal box and replace the clutch cable -
1978 SC Targa |
My pedal cluster looks good.
Still here
When the cable's too loose as in the vid, the omega works "fine". When the cable's per spec, the omega's too weak. I believe that's what I'm hearing from Ivan.
Locker, just my view. After setting up the cable and all adjusted best as you can, go to the front. Is the pedal all the way up? If not, pull your pedal all the way back and then take a look at where the cable attaches to your cluster. Adjust the slack out at that end. See if that cures your issue. Just a thought.
Dan T '85 Carrera Dansk premuff/sport muffler 7's and 8's, Steve W chip Kuehl AC and fresh top end |
After having dreams about cable adjustments, I decided to stop tinkering with it for a day or two.
![]() I'll get back at it and post my results soon enough. |
[QUOTE=Solamar;10842478]
This is the "$5 part" that your mechanic was probably referring to. It attaches the clutch cable to the clutch pedal cross shaft - I think #30 is what went bad on mine. It's been a while, but I remember the mechanic saying "I find these gone bad often. It's only a $5 part" Maybe that is the same as what your pic is showing at the top?
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
[QUOTE=stevej37;10843895]
1978 SC Targa |
I just finished rebuilding my pedal cluster and have started installing a new clutch cable. My cable seems to have much more tension where it connects to the omega spring.
Are you able to tighten the 15 mm nut closest to the front of the car in order to increase tension or have you bottomed out the nut. If so, you may need to get a new clutch cable. They tend to stretch over time. |
Little detour - the little L-bracket was bent enough that I now need to replace it.
"Overnight parts from Japan..."
...well, not Japan, but rather surprisingly the parts I ordered showed up quick! ![]() The casting on the new part doesn't look anywhere near as nice as the original, but dimensionally it's spot on. Maybe the additional aluminum used in the casting is for strength, but something tells me it's just cheaper manufacturing. Not pictured is another circlip for the little finger "just in case" and the little rubber stop that goes on the pedal board for the clutch pedal. Mine is rather tired. Back at it today or tomorrow... |
Time to conclude this project.
The clutch is properly and nicely adjusted as of a couple days (and probably 150 miles) ago. So why was the pedal not returning fully? My answer:
I ended up replacing the clutch stop bracket after Ivan pointed out it was bent, which I admittedly made worse trying to straighten it out. $160 lesson there, but that's how you learn. I replaced the cable boot and the little rubber stop on the pedal board as well. After this thread, and speaking with a knowledgeable local mechanic, it's clear that 1MM (.047 inches) gap is "too much". The procedure I ended up using was:
So in the end, no parts were really worn. The stop bracket was probably "fine" had I not touched it, and the little "bind" in the pedal was due to insufficient cable tension and no lube. That little "cam" in the omega spring is suppose to be there. Thank you Ivan, Solamar, and everyone else who shared thoughts. |
good job...;-) and you are welcome.....
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Still here
Congrats.
I'm always impressed by the precision factory instructions for this procedure. The in spec gap is 1mm with 0.1mm margin according to Porsche. |
Nice! Glad you got it figured out
