Guess where this substance came from?
Just for fun, can any of you identify this substance?
Hint - It's not grease or dirt and yes, it came from my 911SC
1978 SC Targa |
German Caviar
this is from your front or rear shocks;-)
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Control arm bushings?
Looks like what used to be the rubber boots off your real axles
Bilstein strut insert bushings.
Ivan nailed it - Bozo PO left the old bump stops in the front struts when he installed new inserts.
1978 SC Targa |
I would agree with Ivan, front or rear shock rubber stop bushing,
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her! |
1st time i have seen it it was back in the 1980`s me idiot, try to remove it by blowing air in it..you should have seen my face;-))))
Ivan
Of course that meant the PO couldn't seat the shock shaft correctly.
Bigger hammer and busted roll pins, no problem -
1978 SC Targa Last edited by Solamar; 04-24-2020 at 12:51 PM.. |
I went in because the strut DU bushings were shot, lots of play between the insert and strut body.
Pain in the but to remove the bushings, new ones pressed in nicely - ![]() ![]() ![]() ![]()
1978 SC Targa |
Earthling
could have sworn that was black tar heroin
1996 Porsche 993 C4. His 1979 Porsche 911SC - sold... and now BACK again! Hers 2021 Volvo V60 (foul weather drive) 2024 Volvo XC60 (spousemobile) |
Dumb question. Are those strut bushings required in Boge struts when replacing the inserts, or are they only for Bilstein struts only?
Paul 1987 Carrera coupe |
Bilstein inserts are installed upside down from most shocks, shaft down. So the bushings guide the shock body as it goes up and down inside the strut housing. |
Makes sense. I've only read about Boge struts being filled with oil and no mention of bushings inside the housing.
It's a 914 ...
Those bushings are only for the Bilstein struts due to the "upside down" mounting of the shock inserts.
