Gauges?
I’m a bit lost here
Allow me to explain:
1968 911 chassis, original wire harness.
1983 3.0 stock but going with Weber’s
1983 CIS harness. Engine and ECU.
5spd 901 trans
MSD with blaster coil
I have a 77 Speedo
The rest I need to buy.
What are my options here when it comes to gauges?
Any advice on which ones to look for?
1975 911 3.4 outlaw/hotrod? lsd
1988 535i
1987 535is
1973 bronco ranger
Old 11-28-2020, 07:03 AM
Are you looking to have early style gauges with the silver button needles or the later 74-on style?
Your 77 speedometer isn't going to work with a 901 transmission. You will need a speedo with a mechanical "cable" drive.
Here is what I would recommend, but first you need to decide on the style of the gauges.
- Pre-76 mechanical speedometer
- Any fuel/oil temp gauge will work
- 77-83 Oil Temp/Pressure gauge
- Any clock will work
- You can start with almost any tach but you will need to either have it modified or use a tach adapter for it to work with MSD.
Feel free to send me a PM if you need any help getting your gauges together.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 11-28-2020, 10:22 AM
AutoBahned
RWebb's Avatar
I'm not sure if a '68 had the green faced gauges stock or the later black with silver button ones.
If the former, I have some to sell but not a complete set.
Old 11-28-2020, 10:29 AM
68 would have the black face/orange needles. 68-73 look the same.
If the OP has no interest in your green faces gauges I may.
Old 11-28-2020, 10:40 AM
I had one original fuel gauge with the silver dot but it’s missing the glass. Some idiots epoxy primed the car and didn’t tape things like this up and I broke the glass trying to clean it up.
I would like silver dot guages.
I also have a tank/oel gauge 911 641 202 29
Temp/press. 911 641 104 29
A clock that didn’t move when I hooked it up to a battery.
If anyone has any silver dot gauges let me know
1988 535i
1987 535is
1973 bronco ranger
Old 11-28-2020, 10:50 AM
Sent you a PM
Old 11-28-2020, 11:04 AM
