Recommend a stealth antenna
I have tried two different stealth antennas and they are junk. Does anyone have a recommendation for one that works?
Maybe a 'mercury filled' one?
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
I have a manual antenna in the fender that I never got the "key" for - so have never put it up.
Radio works fine; it comes on every 9 months or so when I reboot the ipod that I usually listen to in traffic...
'77 S with '78 930 power and a few other things. |
I recall someone used an oem antenna from some foreign car from the junk yard it ran up and stuck on the inside of the front fender. I always wanted to look around but I forget every time i go. I tried an aftermarket one it was no good. Now in my 914 im using a regular extendable antenna tucked up under the dash laying across the car. It works ok but not great
82 SC , 72 914 |
Retrosound makes a couple different hidden amplified antennas. I haven't used one but they get reasonable reviews.
Why an antenna? pretty soon will have little satellites spewing 5g everywhere, cooking us from the inside out.
I dont have a cell phone. never did and hopefully never will. I have an ipod but the old becker europa doesnt support it.
82 SC , 72 914 |
What about a late air cooled windshield with in internal antenna?
I'm good with tools.
DAMN.... and I thought not having social media was red ass.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
Thread Killer
This was my first thought as well, although a fairly significant and pricey change for an FM antenna.
Another thought would be to get one of the flexible wire antennas (like those that come packaged with audio equipment) and lay it under the back deck padding where it's not visible. You'd have to find a way to connect to car audio antenna wire (solder or adapter?) and run to the dash, but it shouldn't be able to see any evidence of it.
Allen '85 911 Coupe '75 BMW 2002 '02 Ducati Monster 900ie '18 GMC Sierra Denali 6.2L 4wd |
Many years ago I found an antenna at Radio shack that stuck to the inside of my window. I ran it along the edge of the window from the passenger side to the rear view. It's worked for years and I don't even notice it.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
I bought a regular antenna with an amp booster from Pepboys and just installed it and it works fine except when I get the exposed metal base near any of the body work on the car, then it completely goes to static. If I can insulate the base then I can probably mount it under the hood with zip ties and it should be fine. I tried electrical tape and that did not work. Any odeas on some form of insulation?
Porsche930dude: Old Becker radios can be updated to allow a AUX input from a phone or iPod. Prior to 1968 you would have to send it into Becker Sound, but 1968-1984 Beckers have an auxiliary input in the back that you can buy an adaptor for... its really a cool update.
JD21476 I got a powered hidden antenna on Amazon, and it works great. I stuck it to the windshield on the passenger side, near the top and ran the black wire down with the window gasket. Can't see it and I get all the local stations on my Becker.
1973 911T Targa ROW |
