-   -   Turn signals not working (http://forums.pelicanparts.com/porsche-911-technical-forum/1059266-turn-signals-not-working.html)
Baseline player 04-26-2020 10:06 AM
I have a 996 (2001) that the turn signal lights are not working, but when I turn on the
flashers they work. I have checked all the fuses with none of them burned out.
What can be the problem? Do the turn signals and the flashers work off the same relay?
7783911 04-26-2020 01:29 PM
have you checked grounds?
Baseline player 05-01-2020 12:18 PM
996 turn signals not working
Wouldn’t the ground be the same for the turn signals and the emergency flashers?
356911930 05-01-2020 12:49 PM
Probably in the turnsignal stalk. Try wiggling it arounda little more than usual to see if you can help it make contact. If so you will need to replace, or remove and bend the contacts...at least that is how the older 911s work.
Rahl
