bcgreen's Avatar
Headlight knob
I am attempting to remove the headlight knob so I can take out the switch. From what I have read you unscrew the knob by turning it to the left (counter clockwise).
I have tried but it refuses to budge, even with me hold needle nose pliers on the shaft.
1976 911.
66 Shelby Hertz Renta-Racer
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 04-30-2020, 10:27 AM
1976 911.
There are two versions of the headlight switch -- on mine, I needed to first remove the plastic disc with the headlight pic on it, which revealed a small screw -- removing the screw allowed me to remove the knob (the other version comes off by turning the knob counterclockwise to unscrew it from the shaft)
Old 04-30-2020, 10:31 AM
bcgreen's Avatar
How hard was it to remove the plastic disc? Is it rather thin? I placed a flat head thin screw driver, trying to find a lip, between the rubber and the plastic but it wouldn't catch anything.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 04-30-2020, 02:11 PM
Ones on my '77 were easy; foglight/rear window defrost switches were the same. The rubber is plenty thick/hardy, and the plastic disk is also thick. None of it is fragile, unless maybe your rubber is hardened and brittle. Mine wasn't.
Work the rubber back with your thumb and you'll see how it is.
'77 S with '78 930 power and a few other things.
Old 04-30-2020, 02:21 PM
bcgreen's Avatar
It sure would be reassuring to see them separated to see how far I have to dig.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 04-30-2020, 02:30 PM
here's a pic of the cap https://bit.ly/3d2EW5P
here's a pic of the capless knob https://bit.ly/3bTQzvQ
Old 04-30-2020, 02:44 PM
bcgreen's Avatar
Here's mine. Sorry I don't know why it is upside down.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 04-30-2020, 02:57 PM
Formerly known as Syzygy
Canada Kev's Avatar
This is what my late G body was like. Well, mostly. Mine had a nut under the headlight pic on the switch shaft, if memory serves.
The knob came off basically like like how Darrin says, to reveal the shaft with the flat plastic thing below the knob with two little holes or divots 180 degrees from each other. This just screws off.
I used a pair of needle nose pliers with the tips of the jaws in the holes and turned that it off with those. That was it - the switch came free and was able to remove it from behind the dash. It's that flat nut/washer looking bit that holds the switch in place.
Kevin
Old 04-30-2020, 06:11 PM
Mine looks just like the above picture. It did come loose but rotating it, didn’t have to pry anything apart.
Mine is the non-illuminated version. I believe from 87 onwards thay had a different version with internal illumination.
The first time I had to loosen it I pulled the knob forward completely, held it with pliers so as not to put any force on the internals, and rotated left. Eventually it came loose. Maybe carefully apply some penetrating oil on the back of the knob with a cotton swab ?
Now it comes off ‘too easily’ I find if I turn the knob.
1985 Carrera 3.2
Old 04-30-2020, 11:41 PM
bcgreen's Avatar
Mine is not loosening even with pliers holding the shaft. Is it possible there is a screw under the center plastic?
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 05-01-2020, 06:14 AM
Thread Killer
Teutonics's Avatar
Look on the shaft to see if there is a hole drilled through... on my 85 you stick a rod through that hole in the shaft and then unscrew the knob. I used a micro-screwdriver of the closest size to the hole. It took more force than I expected, but popped loose and then I could unscrew it off.
However, yours may have a screw under the cap, so you'll want to confirm that first before putting force to unscrew it.
Allen
'85 911 Coupe
'75 BMW 2002
'02 Ducati Monster 900ie
'18 GMC Sierra Denali 6.2L 4wd
Old 05-01-2020, 07:08 AM
On mine there is no screw/nut holding it. The knob is threaded.
1985 Carrera 3.2
Old 05-01-2020, 07:15 AM
Didn’t know about that small hole ! Good tip.
1985 Carrera 3.2
Old 05-01-2020, 07:22 AM
bcgreen's Avatar
It does have the hole in the shaft and I used a allen. I used quite a bit of force but didn't use all possible force because I didn't want to destroy the knob if at all possible. That's why it seems I am being overly cautious with all my questions.
Could be frozen on the shaft because it may not have been taken apart since being manufactured. That may explain why the turn signal was not fixed.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 05-01-2020, 07:23 AM
sugarwood's Avatar
Yes, there is a 10mm NUT under the plastic cap
https://youtu.be/BEZyFLupu1w?t=35
1986 Bosch Icon Wipers coupe.
Indeed, 1987 has the newer variant light switch with internal illumination
1985 Carrera 3.2
Old 05-01-2020, 07:26 AM
bcgreen's Avatar
I did some digging around trying to find a lip in order to pry up the plastic, that's why I was asking for a pic. to see how thick it is and if I am not digging deep enough.
Mine is not illuminated.
Since I have the hole on the shaft is that a positive indication that I don't have to try and lift the plastic center piece and there is no screw under the plastic?
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 05-01-2020, 07:46 AM
Don’t break it.... no longer available!
Old 05-01-2020, 08:08 AM
T77911S's Avatar
This is the later sw with the screw and what I can do to it
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-01-2020, 08:24 AM
Also make sure you use that hole in the shaft. I think it is there to protect the internals and the rheostat of the dimmer switch, if you exert too much force without holding the shaft you can break the rheostat.
Sorry I do not know if there is a nut under the plastic cap.
Old 05-01-2020, 09:03 AM
