marktodo's Avatar
Head light pigtail
My 69 T has halogens that work on both dim and bright.
Now yellow is on top,white on left, brown right. White is hot.
I am trying to upgrade to SMD, when I plug them in I get nothing. Are the pig tails wired wrong. I’m helping my son get a Ghia together and hot is on top on it.
Mark
52 356 coupe
56 speedster
63 356 Cab?
69 911T
69 912 beater
Old 05-02-2020, 05:08 PM
Rescuer of old cars
Arne2's Avatar
White is high beam hot, yellow is low beam hot, brown is ground. LEDs are polarity sensitive.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 05-02-2020, 05:40 PM
marktodo's Avatar
Where do they go on the pigtail?
52 356 coupe
56 speedster
63 356 Cab?
69 911T
69 912 beater
Old 05-02-2020, 06:27 PM
Rescuer of old cars
Arne2's Avatar
If the lights were designed and built properly, it should just plug in with no changes. If that doesn't work, you'll need to get instructions or diagram from the maker of the lights.
2018 718 Cayman 2.0
Old 05-02-2020, 07:52 PM
marktodo's Avatar
It’s not the lights it’s the car. Pigtail was stripped when car was disassembled for restoration. I put it back together after not taking it apart. It would really help if I could find out what’s correct.
Thanks,
Mark
52 356 coupe
56 speedster
63 356 Cab?
69 911T
69 912 beater
Old 05-03-2020, 04:46 AM
Rescuer of old cars
Arne2's Avatar
Ahh. Totally different issue then. Yellow at the top. Brown on the left side, White on the right. Looks like you have the brown and white reversed.
2018 718 Cayman 2.0
Old 05-03-2020, 08:33 AM
Like Arne 2 said, the white and brown are reversed.
Should look like this
Old 05-03-2020, 03:31 PM
marktodo's Avatar
Thanks for the info I got it done and it works great
52 356 coupe
56 speedster
63 356 Cab?
69 911T
69 912 beater
Old 05-03-2020, 03:52 PM
