-   -   1 left over part!! Help (http://forums.pelicanparts.com/porsche-911-technical-forum/1059484-1-left-over-part-help.html)
wareaglescott 04-28-2020 02:36 PM
1979 911SC
Well I completely took apart the car and put it back together. I have 1 left over part and it is driving me crazy trying to figure it out.
It sure looks like it goes to the wiper fluid but I feel like I have the lines behind the dash going to the sprayers plumbed correctly. Can someone please give me an idea of where else this might go?
http://forums.pelicanparts.com/uploa...1588109802.jpg
proporsche 04-28-2020 02:42 PM
it could be far right-last line in the washer system jet,the other have T fittings...
Ivan
nb6179505 04-28-2020 02:53 PM
Headlight washers?
Sent from my Pixel 3a using Tapatalk
wareaglescott 04-28-2020 03:06 PM
Originally Posted by nb6179505 (Post 10843952)
Headlight washers?
Dont have those
wareaglescott 04-28-2020 03:07 PM
Ivan
I have lines running to both spray nozzles already??
darrin 04-28-2020 03:12 PM
do the windshield washers work?
Reiver 04-28-2020 03:40 PM
Only one left over part....damn. good job!
It looks like it belongs to the washer system...possibly a tank pick up ...that hose looks much like the deleted headlight washer hose I had....I know you don't have them now but wonder if all of the SC's were factory plumbed ...
wareaglescott 04-28-2020 05:59 PM
Haven’t tried them because I’m afraid of shooting fluid all over the wiring if I don’t have something hooked up properly!
Solamar 04-28-2020 06:05 PM
I just replaced all the washer lines on my 78 and id all but guarantee that's your right washer line that connects to the actual squirter.
That thing at the end is the check valve. There is a T check valve on the left one. Then the line runs down to the pump.
Solamar 04-28-2020 06:08 PM
If you feel like replacing all those yellowed lines, I bought new check valves from our host and new lines from Belmetric. Two sizes of lines, main line, then short sections of the next size up to lock all connections.
wareaglescott 04-28-2020 06:39 PM
The line showing in the first picture is what I had hooked up to the right spray nozzle. Do you mean I hook these ends together like in the 2nd picture and then hook the clear line to the right spray nozzle?
http://forums.pelicanparts.com/uploa...1588124336.jpg
Solamar 04-28-2020 07:14 PM
That last picture, you can barely see the blue arrow showing direction.
The darker hose, not the one in your finger, attaches directly to the nozzle
Edit, that might not have been clear. The darker tube attached to the check valve attaches directly to the squirter
Solamar 04-28-2020 07:17 PM
I'll have access to my photos tomorrow, think I also started a new thread awhile back when I redid my hoses.
My washer reservoir had a nasty gelatin substance in it from old washer fluid that kept plugging up my system.
wareaglescott 04-29-2020 12:01 AM
Thank you Solamar!
Solamar 04-29-2020 09:38 AM
I'm sure you've got it figured out, but this is the best photo I found of my lines. The top one goes to the two squirters -
http://forums.pelicanparts.com/uploa...1588178239.jpg
and the replacement hose from Belmetric -
http://forums.pelicanparts.com/uploa...1588178301.jpg
