-   -   Voltage Regulator issue (http://forums.pelicanparts.com/porsche-911-technical-forum/1059516-voltage-regulator-issue.html)
geoff_k 04-28-2020 09:32 PM
Hi
I changed the voltage regulator on my 1984 911.
Drove it a few times and all ok
Noticed Voltage jumping up to 15.1 and then back in spec then down to 12. It Revs do not influence the reading.
I think I have a faulty voltage regulator but asking if it could be anything else
geoff
Ian Comerford 04-28-2020 11:32 PM
Just to be clear, you changed your VR because of what? Is the problem with the new one the same as with the old one?
Artfrombama 04-29-2020 12:29 AM
Check the grounds
geoff_k 04-29-2020 02:47 AM
yes... same problem as before I changed the regulator.
The new one worked for a while.....
Trackrash 04-29-2020 09:52 AM
Originally Posted by Artfrombama (Post 10844505)
Check the grounds
And all the connections between the alternator and regulator, especially the black and blue wires.
John W. 04-29-2020 01:14 PM
Sounds like an intermittent connection. Check the ground strap between tranny and engine first. Then clean up all the alternator ones. I recently polished up all mine when I had a similar Issue. Good luck.
proporsche 04-29-2020 02:10 PM
This.....
geoff_k 04-29-2020 05:41 PM
thankyou
I will give it a go this weekend
