-   -   Welding On Inner Rear Latch Panel, 69 S (using a bottle jack to help...) (http://forums.pelicanparts.com/porsche-911-technical-forum/1059563-welding-inner-rear-latch-panel-69-s-using-bottle-jack-help.html)
rennch 04-29-2020 11:34 AM
Today I tackled more chassis restoration, and I had to use a bottle jack to spread my rear frame rails! The full roll cage of this car had "compressed" the frame rails a few mm, and my replacement panel from Restoration Design was a good 1/2" off from being able to be installed.
This was the jack I eventually used, with a 2x4 against the opposite frame rail.
http://forums.pelicanparts.com/uploa...1588184504.jpg
I was able to use one of my regular floor jacks as a "proof of concept" and got the piece in for measurement.
Quick test fit of the outer rear latch panel piece.
rennch 04-29-2020 11:38 AM
After welding it on and cleaning up the welds.
http://forums.pelicanparts.com/uploa...1588185316.jpg
Then sealed up with a bit of POR15 as a stage 1.
Am excited to get that rear panel on so I can finally fit the quarters.
If you want to see the video of this whole process, here it is:
<iframe width="560" height="315" src="https://www.youtube.com/embed/9bfvl7jyTX4" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
