-   -   inside case concern? (http://forums.pelicanparts.com/porsche-911-technical-forum/1059872-inside-case-concern.html)
Trakrat 05-02-2020 11:51 AM
Should I be concerned about this?
http://forums.pelicanparts.com/uploa...1588445457.jpg
http://forums.pelicanparts.com/uploa...1588445476.jpg
proporsche 05-02-2020 12:16 PM
no you should not every engine case has this ..tube for oil supply to oil press regulator release valve.........
here is some reading
http://forums.pelicanparts.com/911-engine-rebuilding-forum/712724-ultimate-oil-pressure-relief-valve-thread.html
Ivan
Trakrat 05-02-2020 02:38 PM
Ivan
Thanks Ivan.
I was worried that it was peeling and shards of metal could come loose. Wasn't sure if there was some coating that has peeled away and could cause corrosion.
