Rear Bottom Engine Mount Studs?
Hi Peeps. 3.0 race case.
I need to replace these threaded studs with longer ones in order to mount a tow hook, a GT3 muffler carrier and a mount plate for a Lifeline Rain light. Any trick to removal? Can i simply Vice grip the crap out of them and back out? ( of course, with the engine supported from bottom). thanks very much.....SmileWavy frank |
You should be able to double nut them out.
By 3.2 the factory used 10mm bolts Bruce |
Picture will help........
Frank,
Could you post a picture? Thanks. Tony |
He's talking about these studs. That's where those tow hooks attach.
http://forums.pelicanparts.com/uploa...1588484627.jpg |
Thanks Walter. Yes those. And nice weight reduction! BTW. 10mmx1.5 thread. I think i can just double nut them to back out. Maybe use a propane torch on the block. thanks everyone.
nice holes Walt!
studs
They are 10 x 1.5.Usually never a problem with double nut removal.Fred
thanks fred and all. was really quite easy.. not sure why i was so hesitant....
| All times are GMT -8. The time now is 08:05 AM. |
