Senior Member
Zendalar's Avatar
Gonna do my own venturies, what are the measurements?
I am going to do my own venturies, since they are very expensive (my opinion).
Does anybody happen to have venturies at hand so that they could take measurements from it? I am gonna do 32mm venturies.
I got (from another person) some measurements but I wanna be sure
I need the venturi height (45mm?)
Outer diameter (46mm?)
Inner diameter at the wider end (40mm?)
Inner diameter at the thin end (upper end) (32mm?)
Theeen I would need the height (measured from bottom) where the venturi is that 32mm, or whatever the "real" size is of that venturi
Thanks.
Projects:
911 -72T EFI "964-look" "Smoky"
914 -71 1.7 D-JET "Rusty"
Old 04-11-2003, 12:19 AM
Senior Member
Zendalar's Avatar
Oh yea, the carbs are IDA40 Webers
Projects:
Old 04-11-2003, 06:22 AM
rs911t's Avatar
Really? I bought a set of new 36's from PMO for $72. That's one
hour of labor at a local Porsche shop.
Greg
Old 04-11-2003, 08:01 AM
Senior Member
Zendalar's Avatar
Well, here they are 30$ a piece :P Besides, I am going to make 30mm and 32mm, and perhaps little bigger if I have time. I wanna test which ones work best on my engine.
Projects:
Old 04-11-2003, 08:34 AM
rs911t's Avatar
Yikes! Now I understand your motivation!
Greg
Old 04-11-2003, 09:08 AM
