-   -   Why doesn't broken head stud destroy the engine within a few seconds ? (http://forums.pelicanparts.com/porsche-911-technical-forum/1060270-why-doesnt-broken-head-stud-destroy-engine-within-few-seconds.html)
sugarwood 05-06-2020 03:39 PM
http://forums.pelicanparts.com/attac...11-cutaway.jpg
This is something I have never understood. I assume the head stud holds the head in place. There are 2 or 4 per head? There appears to be a long rod passing through the cylinder and head.
If the stud also holds on the cylinder, when it breaks, I would expect the cylinder and head to move. The piston is attached to the connecting rod and has a very tight tolerance. If the cylinder moved, I would think the piston would smash into the cylinder wall, and destroy itself instantly. Why does this not happen, and people drive for years and not even know they have a broken head stud.
Or does only the head move and there is no way for it to hit the piston, since it can't get any closer due to mating surface of head being fixed.
I get if only one is broken, maybe the other cylinders keep it from shifting. But, how many can you get away with. With 2 studs broken, I would think the above scenario would be inevitable.
Travis Neff 05-06-2020 03:54 PM
There are 4 headstuds per cylinder. all headstuds on each engine side bolt the cam tower with the heads sandwiched in between. The remaining unbroken studs hold the load keeping everything together.
sugarwood 05-06-2020 05:23 PM
Thanks. I am guessing 2 broken studs could still keep everything still. Any 2 corners of a square are fixed, the square stays fixed. So, it would take 3 broken studs from the same cylinder for a catastrophic shift in the engine causing interference?
Has anyone ever reported 3 or all studs breaking in the same cylinder and resulting in a catastrophic engine failure ?
john walker's workshop 05-06-2020 07:04 PM
:rolleyes:
boyt911sc 05-06-2020 08:37 PM
Just another Sugar’s favorite.....
:rolleyes::rolleyes::rolleyes:
Rawknees'Turbo 05-06-2020 10:22 PM
Wood, the cylinder and head assembly doesn't move left or right, or up and down (as in up/sky and down/ground) much at all (as in basically not at all), even if many of the studs on a bank are broken (even just two remaining, intact studs would do a lot to steady that kind of movement, as everything is still held together, left to right & up and down, by the cam housing), but what happens is compression and combustion pressures lift the heads that have broken studs, and that allows combusting fuel and oxygen to escape, which then burns/erodes the surface where the heads meet the cylinders - even with such a slight loss in clamping force that there is no escaping combustion, you can end up with slight-movement-caused damage to those surfaces (called fretting).
You are not going to see catastrophic, 911 engine failures due to broken studs, as they do not break all at once (not even the super shiity, dilivar studs that Porsche used for decades and could not get right until the 993TT, do that), and when a couple of them have broken (even just one, for people with experienced and attentive ears), the tell-tail noise of escaping combustion is loud and clear, so someone who is thinking straight will not operate the engine further until repairs are made.
LIRS6 05-07-2020 04:48 AM
no problem.....
I drove my car for years with no issues, save the dirty block and a drip or two .. or ten
http://forums.pelicanparts.com/uploa...1588852021.jpg
Jason
MBAtarga 05-07-2020 06:01 AM
Looks like 3 broken studs above.
sugarwood 05-07-2020 06:11 AM
The hypothesis was 3 broken studs in the same cylinder. Center cylinder has 2 broken.
I will try to find a photo of cam housing to understand how that keeps all 3 cylinders and heads from moving. I am guessing it is like an inverted egg carton with 3 eggs that "cups" and forces things to stay in line.
boyt911sc 05-07-2020 06:35 AM
3 in 1 hypothesis.........
Sugar,
Are you aware why and where the broken head studs always occur? Take a closer look at Jason’s picture and you will find the obvious. The three-in-one (3 in 1) scenario has never been documented or not seen in the last 40 years. I doubt you will find one.
Tony
KTL 05-07-2020 06:50 AM
Your original post does not say three broken studs. It says two. Like Tony mentioned, the upper studs don't ever break. They just don't.
I echo the :rolleyes: by others. Chicken little the sky is falling, here we go again........
GH85Carrera 05-07-2020 06:57 AM
On my 85 3.2 engine I was doing my typical inspection after another long road trip at 150,000 miles total mileage and noticed a wetness on one head. No major leak, but a wetness ain't good.
I took it up to my engine builder and we dropped it, and started looking. Of course to get the head off, is a lot of digging. Got the suspect cylinder and one stud was loose. Not broken, it had somehow backed out of the case. No thread damage, no stud damage. Everyone says "I had never seen that before" and I guess I was the lucky lottery winner.
Of course the engine was grimy and gross after all those miles. If one side had an issue, we had to check the other side. And "while we are in there" struck big time and down the slippery slope to a full rebuild. New ARP studs for everything and rod bolts and might as well......................
donbecker1234 05-07-2020 07:19 AM
My understanding is that although head studs breaking isn’t a “good thing”, the concern is gap between the cylinder and the case, possibly caused by a broken head stud.
356911930 05-07-2020 08:32 AM
Don,
It is the top of the cylinder and the head that will separate, causing fretting that is the worry of permanent damage. This will require the head mating surface to be "cleaned" up some.
Rahl
sugarwood 05-08-2020 07:15 AM
Originally Posted by boyt911sc (Post 10855046)
Sugar,
Tony
Why. I read that it's due to moisture. I did see Franny mention something about upper and lower bolts being different materials since different temps? Intake vs. exhaust?
I see that only the lower studs are broken. Looks like top ones don't break? Hence, never getting 3 of the 4? Thanks!
sugarwood 05-08-2020 07:18 AM
https://youtu.be/-0gUImuE5e0?t=409
sugarwood 05-08-2020 07:20 AM
Originally Posted by 356911930 (Post 10855219)
Don,
Rahl
What if the fretting damage is beyond repair?
Can one simply buy a new cylinder and head?
What do those 2 parts cost these days?
Cylinder is $700
930-103-990-01
https://www.pelicanparts.com/catalog/SuperCat/911M/POR_911M_ENGPIS_pg1.htm
Cylinder head is $1500
930-104-033-06
https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=C ylinder+Head+
juanbenae 05-08-2020 07:37 AM
Originally Posted by john walker's workshop (Post 10854682)
:rolleyes:
:d:d:d;)
GH85Carrera 05-08-2020 07:50 AM
Originally Posted by sugarwood (Post 10856654)
On my engine, just that one stud was loose. All the others were still fine. None were broken. But that one stud allowed combustion gasses to escape, and damage the head a little. So it needed to be surfaced just a bit. Of course you can't do that without removing the head, and that really means all 6 heads have to come off. So a full top end has to be done. It would be really stupid not to do the valve guides, and clean up the valve seats. And since the heads off it is easy to pull the cylinders and check them. And while yer in there the rod bolts can be replaced. But heck, while yer in the re why not split the case and check it all out.
I was real glad we did split the case and the intermediate shaft bearing had a decent amount of wear. One of the rod bearings showed a little bit of a "hot spot" so while we were in there.........
In the end my engine was all better and I love it.
http://forums.pelicanparts.com/uploa...1588949118.jpg
Before
After
patkeefe 05-08-2020 10:26 AM
I think it is only possible to break three head studs in one cylinder if you use the wrong viscosity oil below 20F.
sugarwood 05-08-2020 12:42 PM
I think people who rub their car with a diaper, drive it 200 miles a year, and mothball it 6 months a year since they only drive in 72F or warmer are more likely to suffer broken head studs. Sad !
juanbenae 05-08-2020 01:13 PM
^^^^ that shows just how informed you really are.
proporsche 05-08-2020 01:30 PM
http://forums.pelicanparts.com/support/smileys/wat6.gifhttp://forums.pelicanparts.com/support/smileys/wat6.gifhttp://forums.pelicanparts.com/support/smileys/wat6.gifhttp://forums.pelicanparts.com/support/smileys/wat6.gifhttp://forums.pelicanparts.com/support/smileys/wat6.gif
Rawknees'Turbo 05-08-2020 02:06 PM
The lower/exhaust sides break because the dilivar alloy used was garbage (until the 993TT version) - plenty of instances reported where brand new ones broke upon assembly, which rules out corrosion being the only negative factor.
911pcars 05-09-2020 12:58 PM
The cylinders slide into spigots in the crankcase. 4 studs/cylinder, anchored in the case, snake through each cylinder and each cylinder head. The one-piece cam housing then clamps onto the three cylinder/cylinder head assemblies as one structural assembly. So no.
One or several head studs, even if simultaneously breaking, will not allow a cylinder to fall out or shift to any appreciable distance to implode the engine. This is not to say the engine cannot self-grenade. That requires other major component failure to occur. I’ll leave that scenario to your follow up question.
Sherwood
Bob Kontak 05-09-2020 02:05 PM
Maybe you could get a copy of Bruce Anderson's 911 Performance Handbook and read through it. It would be an investment in your credibility.
Seriously. It's old school. Pretty cool stuff and Anderson is a good writer.
Bob Kontak 05-09-2020 02:08 PM
Lion's share is pitting and axial shear post heat cycling.
Tell your Mom I said Hi.
Rawknees'Turbo 05-10-2020 12:58 PM
Agreed with that - amazing how weak and non-resilient those studs are (must be millennial "studs" :D).
You sister just gave my mom your message, bro! :)
