-   -   Sway bar bushing (http://forums.pelicanparts.com/porsche-911-technical-forum/1060453-sway-bar-bushing.html)
BeeMaster 05-08-2020 10:09 AM
Sway bar bushing
Hi I need help, I have a 76 911s, I am trying to re assemble my rear sway bar. I have the snap on end links. I can not get the white snap on bushing in the metal 45 degree metal link that goes to the bar. My press just squishes it. Any ideas thanks
Tony V 05-08-2020 12:05 PM
I’ve heated mine in boiling water and greased them before using a vise to press them in.
A good sized pry bar is handy in snapping it back on to the ball. Don’t over grease the ball or white bushing.
BeeMaster 05-08-2020 01:11 PM
http://forums.pelicanparts.com/uploa...1588968276.jpg
My father spun up the press/punch on the right and that helped a lot getting them in. He put in his quil/mill and applied pressure then it would try to cock and he wiggle and tap but they are in now.
bkreigsr 05-09-2020 10:07 AM
cut down broom handle inserted between the tire and fender and a 4 lb hammer
You realize the links are sided- right & left.
