Wiper Park Adjustment
I’ve seen a lot of threads talking about reversing the wipers, but is there any way to adjust them slightly further down instead? I feel like if they stopped closer to the edge of the windshield vs. the inch or 2 above where they land currently, that would be just as good. Being a short guy, more visibility is always helpful 🤣
Old 05-20-2022, 05:31 AM
Why not just remove and reset (rotate clockwise) the arms by 1-2 degrees?
Old 05-20-2022, 05:48 AM
Just did this on mine, took the opportunity to replace all the plastic bits. You might have to very carefully pry them up if they've never been removed. - the thing to consider is the distortion that can occur on the driver side wiper blade over time (sitting on the wraparound of the windshield) I've not heard about putting them on the otherside... hrm.
Old 05-20-2022, 05:25 PM
Loosen the nut, lift the arm and wiggle it side to side, and it will come loose. Reset their position and tighten the nuts. Straight arm on driver side, kinked one pass side. I see them backward a lot.
206 637 4071
Old 05-20-2022, 10:05 PM
