You do not close the frunk by pressing the crest
1986 Bosch Icon Wipers coupe. |
Never heard of using the crest for me always over the latch. Interesting video.
Walt 82SC 3.0 81SC 3.6 |
Guess I've been doing it wrong for years...
I never use the crest but.... every P-car salesperson I have ever encountered in a showroom makes a big deal of showing off using the crest as the "proper" way of closing the front trunk lid. UGH.
Brian Miller - Scottsdale, AZ 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S |
Driver, not Mechanic
PO bent my crest. Had to buy a new one.
I think it just became a thing because people dont want fingerprints on the paint. Thats about the last person on earth I would want to paint a car for. Brave man that George
82 SC , 72 914 Last edited by porsche930dude; 05-09-2020 at 03:28 PM.. |
Buy the Rennline hood struts. Then all you have to do is just drop the hood.
Let's put it this way, a correctly adjusted hood will only require gentle pressure to get it to latch/lock.
If you have to push hard enough to worry about dents and breakage, you may want to check out your latch and hood alignment to make sure they are all in the right spot. I always take off my badge as it is too tempting a target for some "youth" with a screwdriver to prise off as a trophy, I just put on the small decal and call it good. ....and yes, not matter what, the best place to press is where there is hood frame support....easy to see where if you open the hood up and check out where the bracing is. Dennis |
when I p/u my 72 at the factory, they told me to close hood by pressing the corners
68 Beetle 68 to 72 sold 72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army 67 VW split window 74 to 76 sold 81 VW caddy 81 to present |
Lash
Pushing down on the crest is considered a point load, so over time will cause the aluminum hood to develop a low spot as per the video.
I've always grabbed the hood with both hands (fingers on the edge of the trunk) and given it a good hard or rather "firm" push, this avoids point loading and always secures it in the lock catch.
Ole Skool - wouldn't have it any other way |
I find it amazing when I see people who have owned the same car for 50 years. That's truly remarkable. Can you tell us more about how you held onto the same car for 50 years? It must be really wild to own something that long.
It’s a pity his car’s previous owner didn’t read the manual supplied with it ...
But then again , what guy needs an owners manual !! ![]() ![]()
The crest is 5" above the latch. I would think that pushing down at the lower point would not cause as much damage.
My 72 was a daily driver for 15 years. I had engine problems and no money, so I stored it in a storage unit for about 12 years. I knew if I sold it, I would never be able to buy another It's great driving now with so few people on the road!
