77 Targa door regulator
I have acquired a 77 Targa. Previous owner removed glass. I have the glass and vents and regulators. Electric motors are bench tested and are good. Regulators are missing
1 pivot "bolt and nut" in each. This "pivot bolt" is centered below the 2 points at the mounting bracket on the glass. I was on and called Pelican to inquire and was told this
is not an in stock availability item. Kinda get that with the purchase of the regulator.
Any suggestions on locating the proper fastener would be greatly appreciated given
the cost of new regulators.
Old 06-16-2020, 09:28 AM
Can you post a pic of the assembly you have or the parts you need? That may help clarify what you are looking for.
Old 06-16-2020, 11:34 AM
Old 06-17-2020, 02:41 PM
apologize for the delay....Im a building contractor and am getting back to work. As you can see, there is a unique fastener that connects the 2 pieces and should allow the "arm" to rotate as the
glass panel goes up and down.
Old 06-17-2020, 02:49 PM
