Irrationally exuberant
New use for old tool
It was really tough trying to hold the ignition wire so I could screw in the spark plug connector on but this old tool (P385) for installing plastic fuel lines works pretty well for this job. :-)
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 05-09-2020 at 10:25 AM.. |
Any recommendations or guidance on plug wires? Possibly in my near future.
1987 M491 Widebody, Nautic Blue / Linen with a 1979 930 3.3L Cali Engine |
1986 Bosch Icon Wipers coupe. |
I had 964 bottom wires with modified 964 valve covers but they leaked.
I ordered a set from Clewett and waited patiently. I called him after a month and he told me he couldn't get the components. (It would have been nice if you told me this earlier, grrr.) I then called our friend Henry and order a set and waited patiently. After a month, nothing. I revisited the problem of getting the wires connected and discovered the cap comes off the top of the plug connector. Now I'm replacing the plug connectors with "3.2" style Beru ones (6 for $190). I'm ohming them out as I go alone. 3 done so far.
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Why did you not order from Pelican?
They have Clewett in stock for $169 https://www.pelicanparts.com/catalog/SuperCat/911M/POR_911M_BASTUN_pg3.htm
Caveman Hammer Mechanic
Got my Clewetts on Pelican, great product, 0.0% hassle.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
I needed a solution for the bottom plugs with connectors that fit a 964 distributor.
I couldn't find this tool anywhere as "P385" but I stumbled across it at a local vendor right down the road from me. That's probably where I got it many years ago.
Maybe Pelican can get for you if you asked? To find it l googled: "T-POLYAMIDE" tool You have to have "T-POLYAMIDE" in quotes. It's $50 at this time (June 2020)
