-   -   no turn signals or hazard warning lights (http://forums.pelicanparts.com/porsche-911-technical-forum/1060546-no-turn-signals-hazard-warning-lights.html)
mark reed 05-09-2020 08:47 AM
had my car 1980 911sc in storage since xmas the indicators were working then but no hazards.
Just got the out of storage and fitted a new indicator relay as old was was damaged .
I now have no indicators or hazard lights or turn signal lights on tacho.
Checked fuses they are fine but there doesnt seem to be any power to relay or fuseboard I recently removed the speedo and had that repaired and that is now installed back in the car.
Is there something behind the speedo I could have knocked or damaged maybe a ground wire or maybe the indicator stalk has failed.
pete3799 05-09-2020 09:03 AM
So are the turn signals working but just no indicator lights on the gauge?
mark reed 05-10-2020 09:36 AM
Hi Pete
I have nothing no turn lights on tacho no turn signals or hazard signals
timmy2 05-10-2020 03:28 PM
Check the round male 6 pin plugs up under the dash above the drivers footwell are fully seated.
