Name that Wiring harness bracket (Air Flow Meter)
In my quest to be completely anal about getting my 88' Carrera back to bone stock original, I noticed I'm missing a small wire hold down 'L' bracket + 'blue' plastic clip that 'restrains' the wiring harness that connects to Air Flow Meter, CSV, etc.
Here's a pic of the said bracket + 'blue' plastic clip (circled in red): http://forums.pelicanparts.com/uploa...1589050000.jpg Here's what it looks like without said bracket: http://forums.pelicanparts.com/uploa...1589050038.jpg Can anyone identify the part# for the angled bracket + 'blue' plastic clip? I searched the PET extensively and found no pics that have this item identified. Thx |
i just thew that out i might still have it.
I don't believe that bracket is available as a separate part number in PET / Porsche's parts system. I was looking for the adjacent idle microswitch bracket, but could never find it. A fellow Pelican eventually replied to my WTB post and sent it my way, gratis. Good luck.
The plastic clip probably from Wurth
http://forums.pelicanparts.com/uploa...1589137286.jpg |
The bracket IS available separately (although I do not understand why it doesn't show up in the PET)...someone raised this issue in a thread a few years ago and I ordered one. I will try to find the paper work to come up with a part number. Alternatively, try a search here and you may find the thread.
@Donporfi - thanks for that. I'll check out Wurth for the plastic clip.
@Lyle O - I did a search and found nothing :-( I may just get a hardware store L-bracket and buy a pack of plastic clips from Wurth. Thanks all!! |
han, I don't have the part number for the metal bracket, but the correct part number for the blue clip is 113.142.261A.
It's a Porsche/VW/Audi part number. You can probably order it from any dealer. |
OK, I found the thread and the bracket (and blue clip) part number(s):
Bracket: 477971881A Clip: 113142261A Parts are actually via the 928 PET. Kudos to the original guy who tracked this down (Missed Approach)... http://forums.pelicanparts.com/porsche-911-technical-forum/886926-looking-engine-compartment-bracket-p-n-2.html |
And it is a special order part here at Pelican
https://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=DWsearch&description=+ 477971881A+ It would be very easy to fabricate, just a 16 or 18 gauge piece of steel with two holes. Or modify one to fit, you just need to cut this one, drill a hole and it is available at Pelican https://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=DWsearch&description=9 1160208301 |
You guys are awesome!
Luv this forum!!! |
| All times are GMT -8. The time now is 11:26 PM. |
