3.2 WOT switch cleaning
My wide open throttle switch is acting odd.
While testing it with an ohm meter, there is an approx 1/2 second delay from WOT to the switch opening. Hold throttle open by hand, wait, continuity. I'm sure I recently saw a thread here that showed a WOT switch opened up for cleaning, but can't find it... Any of you ever clean the contacts in your WOT switch? |
Check Wayne 962 post on his 3.2 transplant in his 914. He tried but broke the switch, so he might give you some valueable tips.
__________________ 1985 Carrera 3.2 |
Thank you Frank! That was exactly the post I was looking for. I 'think' Wayne broke his while trying to remove it from the tight confines of the 914. I'll remove my airbox and AFM so I should have pretty good access. It's just a simple microswitch, should react instantly. Something must have gunked mine up.
1978 SC Targa |
Thread Tools | |
Rate This Thread | |
