Targa_PB_78_SC
mike sampsel's Avatar
SKF Wheel Bearings how many miles
Started the arduous task of cleaning and packing front wheel bearings.
Both my used inner bearings are stamped Germany. I'll assume they are original to the car and have ~ 120K miles and have been packed at least once (by me) after 70 K miles.
The outer bearings:
One is SKF stamped Italy.
The other is unsigned (maybe its a Picaso and worth lots )
The races and the bearings all look good to me. I'm not sure but suspect they will go another 100 K miles.
So while I'm in here, should I use the new SKF bearings I have (new) stamped Mexico? Not sure where the new (current) Pelican bearings come from, one says Japan (Genuine Porsche inner) the other says India (Genuine Porsche outer).
I hate to order new ones and find out they are from Mexico or Brazil. And removal of the races has some risks, but I think I can handle it.
Thinking I'll just pack my used ones with Red line synthetic grease and move on.
Thoughts ... I've read the opinion in other threads. Nothing specific to bearings from Mexico. Panorama suggests: "Now is a good time to change the wheel bearings". Although the article suggests changing the front and rear ball Joints too. Hum ...
PS everything was fine no issues with current wheels, but I've been meaning to repack the wheel bearings and do some other front suspension stuff too. Oh well ...
BareRearedRookie
Old 03-10-2024, 04:58 PM
PCA Member since 1988
If they are well-greased, they should last "forever." I have only replaced front wheel bearings a couple times in my life. And those probably got dirt in them.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-10-2024, 07:10 PM
Alan L's Avatar
Agree - if they adjust up with no issues they should outlast the spindles basically. They are not a high wear item if done properly.
I have a 1991 car (not Porsche ) with umpteen thousands of Ks and original bearings. I know because I am 2nd owner.
If you don't need to change them, don't.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 03-10-2024, 09:53 PM
My '71 Ford Econoline has 300,000 miles on the original wheel bearings. The '82 911 has 265,000 miles on the original wheel bearings. (I'm pretty much a buy & hold kind of guy). Modern grease and proper maintenance makes them last forever.
Old 03-10-2024, 10:27 PM
proporsche's Avatar
Mike ..if it ain't broken why fix it......i have the original on my 911 ..did some greasing about 1/2 year ago still perfect..
ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-11-2024, 12:09 AM
As you have already said, re-pack with Red Line and motor on.
Old 03-11-2024, 02:20 AM
Targa_PB_78_SC
Pete, Alan, smadsen, Ivan and Ian
Thanks guys, definitely nice to get confirmations to my thoughts! Pack and play it is.
BareRearedRookie
Old 03-11-2024, 05:42 AM
I'd use them if they're in good shape.
As others have said, use synthetic wheel bearing grease instead of the original dino stuff. It really does make a difference. I'm partial to Lucas X-tra Heavy Duty grease because I've used it on the track for decades and any wheel bearing problems went away after we started using it.
Old 03-11-2024, 09:49 AM
