For those with magnetic phone mounts...
So I have this:
![]() ...and I also have a few other cars with similar systems. Getting ready to update my phone and was looking for similar metal plates for magnetic mounts - found these: https://www.amazon.com/dp/B09B35RXV7?psc=1&ref=ppx_yo2ov_dt_b_product_details It was something I was thinking about a few months ago and finally measured and looked around for similar. They measure the exact same... Nothing technical, just a find I thought I'd share... Erik
1986 911 Coupe 1986 911 Targa |
Been here a while
I bought a few doodads like this
https://a.co/d/0UB5pjw They perfectly replaced the magnet on the rennline and other mounts. The next trick, you put an open ring on the back of your phone, probably comes with the kit above but even if you have a phone case, it’ll hold the phone to the mount very securely. https://a.co/d/dn2KlfC
looking for 1972 911t motor XR584, S/N 6121622 |
I added the induction charger magnetic head to my Rennline phone mount too. I then drilled a small hole through the underside of the gauge cluster to hardwire the mount into a power source behind the dash. No loose wires getting in the way.
Brooke 1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black) 1952 MG TD with F20C |
PCA Member since 1988
Brooke, I also adapted a Qi charger to my Rennline clock mount, but I still have the wire looped under the dash. I like your inconspicuous hole. I'll plagiarize it shamelessly.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Agree 100%. Looks really good.
