fpvga's Avatar
Help with defrost/fog switch wiring on an 82
Hi there. I have an errant white/green wire with a double connector on it loose in my dash. It comes out of a bundle that also has a white/black and a black wire, both going to the defrost switch. None of this matches the colors in my Bentley manual, though, so Iím confused. I do have a rear defrost, no front. There is a free terminal, labeled III, on the switch.
Does anyone have a proper wiring diagram for an 82, or happen to have their blower out to take a look at theirs?
Briefly, there is also an unused terminal on the back of the fog switch. I donít have rear fogs, so not sure if itís for that...
Any help appreciated! Iíve read a bunch of posts here but none that quite cover me...
Overkill is underrated.
Old 05-11-2020, 04:22 PM
ROW '78 911 Targa
timmy2's Avatar
White/green “spare” is for the Rear fog lamp for euro cars.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, Bitz kit EFI.
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-11-2020, 05:04 PM
fpvga's Avatar
Amazing. Thank you. Does it go to the terminal on the switch that is currently open? Note that I don’t have the switch that turns clockwise after it pulls out (I assume that’s how the rear dogs work...sort of like the windshield defroster)? And also..is there a good diagram of how the rear is wired from the switch? I’ve searched high and low...
Old 05-11-2020, 05:18 PM
ROW '78 911 Targa
timmy2's Avatar
That wire runs directly to the drivers side 6 pin plug to the tail lights.
If you look at the tail light harness there is likely a bundle of 2 wires tied off that would run to the lamp.
ROW supplemental diagrams would show it, US versions do not.
Dennis
Old 05-11-2020, 06:32 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
