Brap
tmaull's Avatar
Metal on metal grinding after suspension rebuild
So I'm buttoning up a rebuild of the suspension on my SC. My front spindles were raised 30mm by Chuck at ER. Went to back the car out to go around the block to settle the suspension down after reindexing the rear, about to start on the front. Make it about 10 feet before I hear the metal grinding. Get the car back on the lift and the a-arm has ground into the 16" front wheels (approved by ER for a 30mm spindle lift).
So my question is the following. What distance a good measurement of the spindle on a stock car? Perhaps mine was raised too far. Second: I had not torqued the lower ball joint beyond hand tight or installed the wedge bolts. How much will that raise the a-arms off the wheels? It looks like I need another 5mm of clearance but I'm not sure I'll get it there. Thus the first question.
Thanks!
-t
1980 911SC Coupe 3.4
1995 Miata
2005 Tacoma
2009 Street Triple
Old 05-10-2020, 04:46 PM
7.0:1 > 11.3:1 > 7.0:1
Thanks!
-t
Really didn't install the wedge bolts? They are a critical load bearing link in your front suspension required To be in place before you even set the car on the ground not to mention move it.
Old 05-10-2020, 09:08 PM
disband
juanbenae's Avatar
30mm sound like a lot. as I recall about 19mm was as much as you could do with a 16" wheel.
Old 05-10-2020, 09:56 PM
Arlo911's Avatar
Hi Tmaull,
First off, everything should be torqued to spec before taking the car out for testing or even for checking heights. It's very easy to forget you still need to tighten bolts or nuts. Recipe for disaster.
Do you have a picture of where the metal on metal contact happened? Did you tighten your front wheel bearings correctly? Did your struts have the bearing races installed? Because some new struts do not have them installed.
Below is a pic of how to (roughly) measure spindle height. The strut is a 934 strut so the spindle is at 64mm.
Old 05-11-2020, 12:31 AM
Brap
tmaull's Avatar
Yeah so got the wedge bolts in and there’s a good bit of clearance. The ball joint pins must have backed out as the car went over the lift plates. Moral of the story, put your wedge bolts in early and often.
Old 05-12-2020, 06:39 PM
Mothy's Avatar
Send a message via AIM to Mothy
That's a relief for you - a solution with what you had just needing to be fully installed and tightened up.
Chuck would know what works so it was more likely to be something else like you found - a simple oversight.
Swapped my WRX Sti MY02 for a Porsche 911SC '83
Keep buying parts to make it look older.
Mid life crisis is now in its 12th year.
Old 05-12-2020, 07:47 PM
