1997 Porsche 911 Convertible top will not open
I have a 1997 Porsche 911 and the convertible top will not open. When I apply the emergency brake the Parking Brake advisory light illuminates on the dash (normal) and also the master warning light (!) illuminates. I don't remember the master warning light illuminating previously??? Any ideas on where to start trouble shooting? Thanks.
Uncertifiable!!!
You have posted in the air cooled forum. Try posting in
Porsche 996/997/991 Forum - Pelican Parts Forums Good luck. Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
My car is a 993 and is air cooled. Why would I post in the water cooled forums???
Not sure what the master warning light is referencing. Check your owners manual. 3.2 Carrera, 964 and 993 have a similar system. Common issues are a break in the wiring harness where it bends and unbends as the top opens and closes. Also a couple of micro switches on the arms that attache to the passenger side top transmission can get out of sync. The control unit is under the passenger floor board and there is a factory step by step trouble shoot procedure. You can unlock the front locking motors manually. It is a fairly complicated system, until you figure out how all of the parts work together, as power tops tend to be, just be glad it isn't hydraulic
Most likely it's an intermittent ECU behind the dash by the light switch.
Dave |
Uncertifiable!!!
Porsche 964 & 993 Technical Forum - Pelican Parts Forums Good luck. Johan
