Liqui Moly Classic - 20W-50 in a 3.2 1985
Hi folks,I was just doing my spring cleaning and repair list.I bought the oil change kit from our hosts Liqui Moly Classic - 20W-50,as recommended for my 85 3.2, and proceeded to do the oil change. Now my regular 911 drip drip has turned into a gushing type of affair.Was this oil the wrong recommendation?
Old 05-13-2020, 02:40 PM
what oil did you previously use? Where's the gusher coming from?
Old 05-13-2020, 02:49 PM
Doesn't seem likely that your oil change caused a a major oil leak. Did you use new aluminum washers on both drain plugs? I'd clean the bottom of the engine to see where the leak is. Perhaps an oil line got disturbed and has started to leak.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 05-13-2020, 02:52 PM
AndrewCologne's Avatar
Liqui Moly is a high quality brand from Ulm/Germany. I used it for many years with no Problems.
An optimal zddp quantity is here also a plus.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 05-13-2020, 09:16 PM
proporsche's Avatar
Andy ,lets see pictures of the oil leak
Ivan
1985 911 with original 501 708 miles...807 421 km
Old 05-14-2020, 01:11 AM
Yea, let's see some pictures. It could be coming from a dozen places, some of which are easy to fix.
'66 912 - Polo Red;
'74 911s - Silver Carrera RS clone
'77 911s - Peru red IROC Clone
'89 964 C4 - Guards red
Old 05-14-2020, 09:17 AM
