-   -   My 3.2SS build. (http://forums.pelicanparts.com/porsche-911-technical-forum/1061335-my-3-2ss-build.html)
JackkTheMackk 05-16-2020 03:24 PM
My 3.2SS build.
I knew I had two broken head studs so I started the rebuild of my 3.0 finally. Plans for the build are
3.2 Short Stroke
98mm 10.5:1 JE Pistons, skirted.
Twin plug JB racing Dizzy
PMO 46
DC60 Cams
JBR straight cut I/S gears
Valve job and CNC porting on the late SC heads by Xtreme. Drilled for 12mm lower plug. Will be matching Carrera head specs.
Race springs.
Supertec head studs.
ARP rod bolts and flywheel bolts.
1 3/4" QSC V band headers
991 GT3 muffler
RSR flywheel and sachs aluminum pressure plate
GT3 oil pump, cross drilling crank main, grooves main bearing
GT3 main and rod bearings.
Carrera tensioners kit
Open to suggestions from anyone if I'm missing some fun parts. I slipped down the slope and am tumbling now.
Thats the gist of it. If I'm going to split the case and do this, I want to tick every "while I'm in there" box because I'm young and have no real responsibilities at the moment.
Pulled the motor myself in the driveway. Here's happy me after I got the engine on the stand. Used a chain at the cross member side and a tow strap around the rear hook to meet the chain at the front. Really easy way to get it up. Harbor freight hoist for $140, cheap and does the job great.
I found one head stud while pulling the tin. Next up was pulling CIS off and exhaust to get down to a long block. The exhaust was RUSTY. Originally a Michigan car. All 6 Allen key nuts came off no issue, the 13mm nuts were a different story. I took a Dremel to all 6 to split them open and whacked them with a large flat head and hammer to pop them off. The studs will get replaced to didn't mind grinding into them.
After pulling the manifolds, cross over, and cat in one piece, I worked on the lower valve covers. Found 4 broken head studs in total, even though the car ran great before pulling it. Day one, thats a wrap.
Now to further tear into it and get a look at the pistons and cylinders. The CIS, dizzy, and miscellaneous parts will hit the classifieds soon if anyone is interested. I am really a parts hoarder, but to be honest I really don't see myself ever using CIS in the future so its time to make room.
Also, the RD350 I just finished restoring in the background is for sale ;)
http://forums.pelicanparts.com/uploa...1589670531.JPG
http://forums.pelicanparts.com/uploa...1589671111.JPG
http://forums.pelicanparts.com/uploa...1589671170.JPG
JackkTheMackk 05-16-2020 09:36 PM
Down to the long block tonight. Waiting on some Stomski tools to come in the mail and then I can get started on disassembly down to a short block. Stuck until I get a P9191 tool for the cams so in the mean time I'll be cleaning the engine bay and cleaning the 915.
Any tips for cleaning up the 915 case?
http://forums.pelicanparts.com/uploa...1589693679.JPG
nb6179505 05-16-2020 11:22 PM
Sub'd thanks for taking us on this journey with you. I'm in the same boat with my 3.2
Sent from my Pixel 3a using Tapatalk
macssc911 05-17-2020 05:50 AM
Sounds exactly like my engine, finish mine about 3 years ago recommend using ARP case and crank as well, take a little more time balance rods pistons
Good Luckhttp://forums.pelicanparts.com/uploa...1589723349.jpg
JackkTheMackk 05-17-2020 06:52 AM
The entire rotating assembly will be balanced.
I plan on using ARP rod bolts and supertec headstuds. Not sure if there’s any reason to go for the ARP case through bolts.
shoooo32 05-19-2020 09:15 AM
Congrats on taking the plunge! It's pretty terrifying at first but once you get rolling it's the best. Other than leaning over a solvent tank for like twenty hours removing the POs excessive sealant use, it was one of the most fun projects I've done.
LakeCleElum 05-19-2020 10:30 AM
Great project. Very nice RD350.....
David 23 05-19-2020 11:27 AM
Pretty similar core to mine. I added Pauter rods and twin plugs, and modified GT2 cams (Rasant Products did the build) to the core build. Also used RSR High Butterfly ITBs and distributerless EFI rather than carbs.
The 3.2SS with this high compression is a dream engine, you are going to love it.
http://forums.pelicanparts.com/uploa...1589916127.jpghttp://forums.pelicanparts.com/uploa...1589916127.jpg
JackkTheMackk 05-19-2020 11:30 AM
:D
http://forums.pelicanparts.com/uploa...1589916519.jpg
JackkTheMackk 05-19-2020 11:36 AM
Looks amazing. I considered Pauter rods but they’re the same weight and I’m not spinning the motor fast enough to need them.
What are the heads ported to?
I went back and forth with EFI and carbs but ultimately decided PMO’s would be the easiest, most cost efficient, and sound the best.
JackkTheMackk 05-19-2020 11:38 AM
Thanks, going on Bring A Trailer next week!
David 23 05-19-2020 11:45 AM
The heads are stock large bore SC heads. I wanted some rev "cushion" so did the Pauter rods. We dyno tested to 7400 and it was still pulling strong. I feel if I missed a shift I could get away with higher revs without damage. They were done more as insurance than as necessity.
JackkTheMackk 05-19-2020 11:50 AM
What HP did it make?
'76 911S 3.0 05-19-2020 11:57 AM
This is what my 3.2SS made with single plug, 9.5:1 JE's, 964 cams, single plug, big port SC heads, and CIS still in place on a Mustang dyno:
http://forums.pelicanparts.com/uploa...1589918209.jpg
I believe the RPM calibration was a little off as well in this run.
David 23 05-19-2020 01:18 PM
Mine did 290 at the crank. 10.5:1, twin plug, EFI as pictured in previous post, AEM Infinity.
David 23 05-19-2020 01:35 PM
Originally Posted by JackkTheMackk (Post 10871719)
Yep.
http://forums.pelicanparts.com/uploa...1589924042.jpg
chrisbalich 05-20-2020 09:16 AM
Jack,
Are those HF jack stands affected by the recall?
#dontdie
Jonny042 05-20-2020 09:27 AM
I'm looking forward to reading every word of this later..... but have to say, nice RD!!
Carbster09 05-20-2020 10:14 AM
David 23, pretty sure I followed or attempted to follow you at last years Targa Cali. I have a stock '71T, Ivory. It was one of several there. Dave at TRE did the suspension so on the twisties it was good, ... but the little T quickly ran out of steam once it got serious. I really like the Rasant stuff; however Dave had a built 3.8 on the shelf and ready to go .... that and a built 915 was to be my recipe for Targa 2020. Next year or maybe the Baja. In the meantime I have relocated, yet again ... I think the car will be nice here in Scotland, lot of nice roads in the Highlands!
David 23 05-20-2020 10:33 AM
The Targa was amazing don't you think? What fun! Dave at TRE does most of the work on my car, he is the best! If he set up your '71 then it must be fantastic. I was really sorry to see the 2020 TC cancelled, but plan to hit the one in 2021, and in the meantime make good use of the local canyons. I'm sure you will have a great time with your car in Scotland. Keep in touch via PM or email, and send pics.
