Here's how mine came out. It is the one from Daniel Stern. I stuck it to the rear shelf with Blue Tak, but may change to adhesive-backed hook-and-loop.
78 911 SC 89 Range Rover 91 318IS 95 Ducati 916 86 Cagiva Elefant 5 bicycles |
Thanks for commenting.
I will wait further --- patiently. FYI --- it has been ~ 10 says since I sent the inquiry to Stern. Quote:
Member 911 Anonymous
Which model did you buy?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
OK Gentlemen,
Found this alternative to the slow response by Daniel Stern: It states it will accomodate 26-75 degrees, seems allot but priced well: ![]() http://www.rallylights.com/detail.aspx?ID=1805
Same thing happened to me when I placed my order Sept last year. It took about 2 weeks for Mr. Stern to acknowledge my faxed order due to a family matter that took him away from his desk. Ultimately, though, the order did arrive. I'm not supporting this kind of customer service, just reporting my experience for your information.
Dave & Tonya
I like the LED idea, that's what i want to do!
I used the Hella Model 37, 20-36 degrees, from Daniel Stern Lighting. It fits my SC coupe perfectly.
Phil
Detached Member
I did the one from the OP, works great. The trick is to get 2 hour black epoxy and cut a piece of PVC or two to fit to jam it in between the rear deck shelf and the mounting brackets while the epoxy sets.
Hugh |
Rescuer of old cars
Ooooh, good idea! I think I'll change mine to hook-and-loop.
"Honestly now, did you spend your youth dreaming of someday owning a Nissan or Mitsubishi?" - Porsche ad from early '90s 1972 911T coupe Priors - '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Banned but not out, yet..
Since my last post on this thread, I went even more stealth with a far smaller yet much brighter LED setup at the top of the window. It has the added bonus of flashing 4 to 5 times to really get people's attention before going into a steady red. The wires were run though the rubber window seal. The only bummer is that you will need to fab a small bracket to attach it to. It does come with with a self-adhesive back which I used with my bracket. I did not connect the running light wire.
Knight Rider Non-Sequential Dual Intensity 12 LED Light Bar with Flashing Brake Alert - Red Knight Rider LED Light Bar and a video: Knight Rider Non-Sequential LED ![]()
An air cooled refrigerator. ‘Mein Teil’ |
...these look great...now to compare the Knightrider vs the Auto^one long led strip 3rd lite version...
I like the flashing part of the Krider lite...after all , this lite is to get attention vs another red lite turning on... Thx, Bob
I live for 911 tweaks... |
I have this long LED light available for $10 plus shipping - works fine. No mounting hardware, just the LED in its black housing - just apply with double stick tape to it's back. PM if interested.
This is how it looked double sided taped to rear deck - which does not obscure vision ![]()
An air cooled refrigerator. ‘Mein Teil’ Last edited by RSBob; 05-01-2012 at 05:46 PM.. |
Here's how mine looks in the daytime, no brakes. I changed the fastening method to a strip of adhesive hook-and-loop tape. It isn't going anywhere.
Phil ![]()
Thx everyone...
RSBob I sent you a pm not having looked at this thread... I am sending you another pm now...Thx
Bannd
Cars and Cappuccino
These are on sale right now. 25% off. Under $30 shipped within CONUS. Just bot one after being tailgated heavily twice in the last month. Probably just over-curious looky-loos, but scary nonetheless.
Cheap insurance in my book. Car Safety with the Quick Brake Flasher
http://www.carsandcappuccino.com 1987 Cherryrot G50 Coupe - SOLD 1985 Prussian Blau M491 Targa - 1 of 65 in the US 1977 Mexico Blue flared, 3.2, back date, sunroof-delete Coupe - under refinement. 1972 Black T coupe to Longhood Turbo R5 tribute car (someday) |
Can you give us your review of this product and maybe a picture of it installed? Thanks, Thor
1978 SC coupe #1834 |
Cars and Cappuccino
Happy to Thor. Likely this coming Saturday before I receive it and install it.
Rescuer of old cars
I've decided that the big light I mounted low on the window wasn't cutting it for me, and am now moving in the LED strip direction. I looked at the 9" from HB, but bought a similar 5" from evilBay instead. Looks like the same light as the 9", just shorter. Less than $6 shipped. I wrapped the back with black electrical tape, and that turned the whole thing black, it should be almost invisible when not lit. Will post again when I get it installed.
I put a LED strip into the vent above the rear window on my SC:
![]() Worked fine and is bright enough at night. |
Thread Tools | |
Rate This Thread | |
