On an SC the fuel pump should not run with the key on. If it does,
The cold start plug and the airflow sensor plugs are backwards Or the AFS is unplugged.
Bruce
Old 05-24-2020, 03:11 PM
Lifted the car, turned out to be a loose yellow wire to the starter
Also slight oil leak
Old 05-27-2020, 01:38 PM
Got it running? Well done!
Old 05-27-2020, 01:45 PM
Yes, such a simple thing
Old 05-27-2020, 02:30 PM
well, that's good news!
'80 SC Targa
Avondale, Chicago, IL
Old 05-27-2020, 03:13 PM
Amateur
pmax's Avatar
Originally Posted by lada03 View Post
Now, that's what I called a pothole or was it a curb ?
I don't need that.
Old 05-27-2020, 03:16 PM
Hard to tell, but Chicago is one giant pothole)
But if i hit a pothole or bump as i was driving the car would have died on the spot?
I actually parked the car like I normally do in the garage and the next day no start
Old 05-27-2020, 05:33 PM
Vintage Owner
Jack Stands's Avatar
The car would run just fine with the yellow wire disconnected, just couldn’t start again.
84 Targa
70 914-6
73 914-6 2.7 conversion (sold)
75 GMC Motorhome
Old 05-27-2020, 06:33 PM
It happened again((((
Drove this morning, then parked the car and 4 hrs later no start
Lifted the car, starter wire was in place. I tapped the starter with a hammer, still no start
Old 05-30-2020, 03:30 PM
car wont start
I had a similar situation a few years back...
It was determined that the yellow start wire had a short somewhere between the ignition cylinder and the starter. To avoid replacing the 11 wire strand which is quite expensive, my mechanic (skilled and very knowledgeable) replaced the yellow wire in each section of the strand by disconnecting the original yellow wire in each section of the strand and installing a fresh and proper size yellow wire from the ignition to the engine compartment end of strand (LHS WALL) and from there to the starter...
Never had an issue since...
Old 05-31-2020, 04:02 AM
Thanks for the tip
Old 05-31-2020, 04:28 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Can you disgnose the starter/selenoid by lifting the car from the driver side or the rear?
I think the starter is on the right side, unfortunately i may not have enough room to jack it up.. too close to the wall
Looks like a crime scene....
Gary R.
Old 05-31-2020, 04:44 AM
:)))) we got him out in time
Old 05-31-2020, 05:09 AM
Pedro '84 Coupe's Avatar
Please tell me you have jack stands under the car. That is very dangerous getting under there with just the jack as support. I suggest getting some good ramps at the very least. I can't afford the nice Blaupunkts you advertise occasionally but I do enjoy seeing the ads and would hate for you to stop posting because you were crushed by your car. Sorry to sound alarmist but I want you to please be safe!
1984 Slate Blue Metallic Carrera Coupe, 2000 Boxster S and 2016 VW Golf
Old 05-31-2020, 06:32 AM
Thanks for your concern, yes ofcourse i put a jack stand under the car for safety
P.S
There is a Blaupunkt for everyone, i will hook you up and make it work if you need a certain model
Old 05-31-2020, 07:24 AM
Excellent! Thanks for putting my mind at ease. Thanks for the offer! I'll keep an eye on your ads
Good luck on the car. I hope it's something simple again.
Old 05-31-2020, 07:34 AM
