Chicago “house mechanics” - Help
Hello,
I have been enjoying my 911sc as a daily driver all week, drives great.
2 days ago, i parked the car in my garage and now it wont start.
The battery is good, i cleaned the contacts and terminal.
When i turn the key, i dont hear the relay switch on, but do hear the fuel pump.
I think it’s something to do with the wiring connectivity or starter/selenoid issue.
Unfortunately i live in the city, dont have the tools or skills for that matter to diagnose the starter and track the wiring issue
Any local pelicans that can assist? I would hate to tow the car for probably i minor issue
Old 05-24-2020, 05:46 AM
GG Allin's Avatar
Where in the city?
1988 911 - 3.6 - 12 Plugs - Carbs
2016 4Runner
1995 M3 - LS2 - Gone
1991 M5 - Gone
1993 RS America - Gone
Old 05-24-2020, 06:20 AM
tobluforu's Avatar
Get under and check the wiring to the starter, if all looks good, take a hammer and whack the starter a few times.
Old 05-24-2020, 06:51 AM
lada03, where in the city are you? I'm in Avondale.
'80 SC Targa
Avondale, Chicago, IL
Old 05-24-2020, 08:07 AM
JackkTheMackk's Avatar
The starter does not crank over but you have appropriate voltage? Most likely a bad starter.
1982 911 SC Targa - Guards Red
1986 944 Turbo - Zermatt Silver
ZeroFuchsGiven.com
#ZeroFuchsGiven
Old 05-24-2020, 09:51 AM
al lkosmal's Avatar
I have had this occur when the ground strap between the chassis and tranny is not providing a good ground.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 05-24-2020, 10:35 AM
Talking
Be careful with that Otter guy !
Old 05-24-2020, 11:15 AM
...VFC Engineering in ravenswood - Doug Hillmann might do a house call just wear a mask!
Old 05-24-2020, 11:17 AM
regards,
al
+1 Also, thoroughly clean the battery terminals. They can look fine, but have hidden corrosion.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 05-24-2020, 11:22 AM
If you don't have sufficient amps through the + cable and grounds, you can still have voltage that doesn't do much to operate the solenoid. Remove the + clamp and the red wires and squeeze the factory crimp with some big visegrips. Fixed the same issue last week by doing that.
206 637 4071
Old 05-24-2020, 11:47 AM
Banned
How do you know that ?
Jumper cables, or call AAA and they will test the battery for you, if you don't have them.
Old 05-24-2020, 01:15 PM
Originally Posted by GG Allin View Post
Where in the city?
Im on western and division (whicker park area)
860.402.9354
Old 05-24-2020, 01:33 PM
I have a multi meter and the battery showes 12.78 (not cranking)
When cranking, it was very low.. just fuel pump running
I dont hear a relay click on, i think the issue is wirh selenoid/starter or maybe ignition switch?
Old 05-24-2020, 01:36 PM
Where in the city?
Whicker park/ukr village border
Old 05-24-2020, 01:38 PM
regards,
al
Yes from research also a posibility.
Need to jack up the car, dont feel comfortable doing it myself
Old 05-24-2020, 01:39 PM
That would be great.
My other option is towing it to midwest performance. But im sure its a minor thing, and guy that know what to look for will figure it out quickly
Old 05-24-2020, 01:42 PM
Stick a fat pin into the yellow wire at the ignition switch and give it 12V. If the starter works then, it's switch related. If not, bad grounds or what I posted in post #10. Could alway be the starter of course, but do the checks first before spending money on a starter.
206 637 4071
Old 05-24-2020, 01:43 PM
Can you disgnose the starter/selenoid by lifting the car from the driver side or the rear?
I think the starter is on the right side, unfortunately i may not have enough room to jack it up.. too close to the wall
Old 05-24-2020, 01:50 PM
Can i buy you a plane ticket to fly out here? )
You would figure it our quickly. I just dont have the knowledge to do the diagnostics
Old 05-24-2020, 01:54 PM
If anyone has time to help me out over the next few days, i would really appreciate it
Old 05-24-2020, 02:32 PM
