Joehand1's Avatar
Rust Removal on Chrome 1966 Rims
I just bought an early painted dash 1965 912 (I am here because more folks are looking in than the 912 forum) and it came with Lemmertz chrome finished steel wheels.
Unfortunately the outer parts of the rims have rust clusters but the center discs and emblems are fine.
Has anyone used coke-aluminum foil or the Lime Away product on rusty chrome wheels?
I am considering trying that vs sand blasting them and painting them with primer and Duplicolor DAL1679 Silver Acrylic Lacquer.
i am not up to spend big money on re-chroming them as I have lots to do with the restoration of the rest of the car.
1987 Porsche 911 Carrera Targa
2006 Ford GT-Tungsten
2017 BMW M240i
1965 Porsche 912
2018 Mercedes AMG GLE 43
Old 05-23-2020, 05:56 PM
Don’t use duplicolor on your car stuff is crap and your wheels will look like crap spray painted. Try some fine steel wool followed by buffing compound won’t be perfect but will look acceptable if your careful.
Old 05-24-2020, 09:04 AM
Joehand1's Avatar
I dunno, a close friend did his wheels that way and this is the result. Nevertheless I’ll try the steel wool and rubbing compound first.
Old 05-24-2020, 10:47 AM
The 9 Store
I polished up my motorcycle pipes with water and aluminum foil. It doesn't make them new but it sure does look better. The pic shows one before and one after. Took about 15-20 minutes for each pipe. If it doesn't work, the only investment is a couple minutes of your time. It doesn't do any harm to the part.
All used parts sold as is.
Old 05-24-2020, 11:02 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
Is polishing with aluminum foil and water as simple as it sounds? Tell us more.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 05-24-2020, 12:18 PM
Joehand1's Avatar
I used aluminum foil and Diet Coke, and then fine grade wool and industrial lime and rust removal and then polished.
Looks great but not perfect.
Maybe rechrome later...
Old 05-24-2020, 03:00 PM
Joehand1's Avatar
Old 05-24-2020, 03:14 PM
The 9 Store
Yea, it's simple. I had googled how to polish rusty chrome. Using coke might be better or easier but I don't drink soda so I didn't have any on hand when I tried it. It won't work where the chrome has rusted completely away but it's been over a year and my motorcycle pipes look almost the same as when I first polished them.
Old 05-24-2020, 03:35 PM
chapo's Avatar
Steel wool and wd40
Patrick
Old 05-24-2020, 06:23 PM
Reiver
Reiver's Avatar
Originally Posted by chapo View Post
Steel wool and wd40
This
De Oppresso Liber
Strength and Honor 5th Legion
Old 05-24-2020, 07:49 PM
I have used aluminum foil on rust it knocks the rust off and doesn’t damage the chrome. Not sure about the other added liquids make sure you wax after.
Old 05-24-2020, 09:38 PM
djpateman's Avatar
So, is the aluminum foil used as an abrasive? Happich Simichrome Polish is a great product to use.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 05-25-2020, 08:44 AM
Joehand1's Avatar
Yes it’s actually removes the rust with help of Diet Coke.(Regular Coke is sticky) I also used fine steel wool and lime-rust removal liquid from the locsl Dollar General after that, then I polished it.
Old 05-25-2020, 07:19 PM
bugstrider's Avatar
I’ve used comet and #0000 steel wool. It works.
-Palpatine (Robot Chicken)
1978 911SC Targa
Working Projects: 1968 912
Old 05-25-2020, 08:17 PM
