Dept store Quartermaster
lendaddy's Avatar
930 Monty dual out install? Hmmmm
I am going from stock muffler to Monty dual out and have some questions. When I have test fitted the muffler on the turbo I have noticed that it does not sit very square to the motor. The tip on the passenger side seems to exit pretty much straight back and level. The drivers side tip is pointed more to the side and does not stick out as much as the P-side tip. Is this normal? I assumed that both tips should exit parrallel and pretty much straight back, but I could be wrong. Do duals on a 930 tend to have the drivers side exit a liitle different from the passenger side? Thanks guys.
Cornpoppin' Pony Soldier
Old 05-19-2003, 06:20 AM
that is normal with the monty. you won't even notice it later. that's with the new side pipe, right? turbo position affects mufler position, needless to say.
206 637 4071
Old 05-19-2003, 08:05 AM
lendaddy's Avatar
Yep, I thought it might be normal. Someone from another site siad something about a special muffler bracket that Monty uses for their mufflers. Ever heard of this? Thanks
Old 05-19-2003, 08:13 AM
you just cut and tweek the original to the monty shape and run the strap around it.
206 637 4071
Old 05-19-2003, 08:23 AM
lendaddy's Avatar
Fair enough, thanks again JW!
Old 05-19-2003, 08:25 AM
Send a message via Yahoo to Lukesportsman
Do you have pics? I'm sure others would like to see also.
Luke
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 05-19-2003, 10:48 AM
lendaddy's Avatar
Pics of the muffler?
Old 05-19-2003, 10:55 AM
