Need to see your narrow body's stance
I know there are 100+ pages of pictures of great looking stances from the other thread but there are just too many pages to look through but I'd like to just have all the narrow body G Bodies here.
Please post pictures, plus wheel and tire sizes also.
Bruce - Socal '76 912e (e for electric, thus not 912E) Emerald Green project car '19 GT3 RS Lizard Green track car '19 Carrera T Carrera White family car |
sportier is 4x 7x15 ET23.3 w/ 195/65 tires +1 from that is 205/60 tires an extreme Fuchs is 7ET23.3 front an 8 ET23.3 rear oe Fuchs limit this to x16 and the tires have to be very selectively chosen factory had a 7ET49 wheel but it has too much back space and has to be used w/ a spacer to get b/s below 6", 21mm spacer is the most common size. Better to to get custom o/s wheels
Registered Minimalist
Like a duck to water
You all knew I would show up to this thread...
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
75 911S, lover your choice of black wheels and white car, and could you please tell us the size of them and the type and size of your tires?
15X7 911R Replica Maxilite (49ET) w/ 18mm spacer in back 225/50 Pirelli Trofeo R
15X6 Fuchs w/2mm spacer 205/50 TiPorsche Products Silver Ti Lugs on 72MM studs ![]() PS The really good photos are by Jakkthemak
I have 4 15x7 Cookie Cutters, do you think I could run 15x7's up front with 225 tires also (I'm not afraid to roll the crap out of those fenders)?
The nice thing about 15s is that they are short, you can probably run 225/50 on the 7ET23.3 Cookies, they do stick out to the edge of the danger zone but they are also so short that at most ride heights it's ok
Designer King
4 205/50/16 BF Goodrich G Force Sport Comp 2 on 7" Fuchs. 6mm spacer on rears. I like the lowered look of the car plus the added acceleration of the smaller diameter tire. Having 7" all around allows easy rotation.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L '80 SC engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Goodrich G Force Sport Comp 2; PCA/UCR, MID9 Never leave well enough alone |
Great looking car, Paul. Looks like it needs to be driven. And driven.
1990 964 Coupe 1986 Carrera 3.2 Targa |
And did you have the fenders rolled?
AND... they aren't too expensive at all when compared to the same tire in 20" and 21" sizes ($700+ per tire ![]()
Designer King
Bli8 and RedCoupe,
Thanks for the compliments. Ol Yeller has 197,000 miles on it, incl 95,000 on the modded engine. I have rolled the rear wheel arches.
Designer King
Rear View. I'll see if I can get one that shows tire width.
![]() 15X7 FRONT 15X8 REAR 205-50-15 FRONT 245-45-15 REAR |
You have flared fenders in the back though. Correct?
So you changed from a 205 to a 245 in the rear?! I remember this post from last year where you stated you MIGHT be able to fit a 225 in the rear, let alone a 245?! Can you elaborate?
Photos of 15x8s on my narrow body '74
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, ARP Rod Bolts, Big Port SC Heads, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
see www.lyallbaybeach.co.nz |
Actually... Double thanks haha, she now says 'That... would go nicely with my new yellow Porsche."
Thread Tools | |
Rate This Thread | |
