Pilot bearing installation 78 SC, which way do I install?
I have a new bearing and I can't remember which way to install the bearing or how deep. The bearing has a flanged end which is up in my photo. The flywheel is modified for use with a 901 trans in a 914.
http://forums.pelicanparts.com/uploa...1590946350.jpg |
From the inside. Then lube it.
Correct.
Thank you!
| All times are GMT -8. The time now is 04:27 AM. |
