sean m's Avatar
Targa Top Part
All,
Noticed a few days ago that I was missing the middle, front screw on my targa top.
After tying every screw and bolt I could find ( I even sent a note to Dan at Carsinc for help) all to no avail.
I reached out to Pelican and they sent me this part. My question is how is it secured? There's no threads on it.
What secures the pin to ensure it doesn't fall out again?
Thanks for any help
Sean M
'77 911S Targa Ice Green
Old 06-18-2020, 11:02 AM
The pin is press fit. get the old pin out and push
the new one in. Looks like the head of the old one got
knocked off.
Old 06-18-2020, 12:06 PM
tholyoak's Avatar
It is retained by a circlip. That is why there is a groove in the end of the shaft. There is usually one or more plastic washers that shim the circlip
1989 911 Targa
Old 06-18-2020, 12:17 PM
sean m's Avatar
Nomore.......there's nothing in the hole. The pin is completely gone.
Thanks for letting me know I don't need anything to secure it. I thought like tholyoak that there needs to be a circlip or something to keep it from falling out.
Sean M
Old 06-19-2020, 03:56 AM
tholyoak's Avatar
The circlip is #28
1989 911 Targa
Old 06-19-2020, 05:19 AM
Sorry I thought the pin was still there. You would have seen the circlip in that case. Tholyoak is correct about the circlip. You can probably get one easy enough at the hardware store. good luck. John.
Old 06-19-2020, 11:52 AM
sean m's Avatar
Perfect...thanks for you help
Sean M
Old 06-19-2020, 12:18 PM
Targa top parts
Yes a plastic bolt holds the two arms together. A plastic push clip hold the vinyl arm trim in place. It is the same one that is used in the front corners. Also you really don't need that metal cir clip If you ever replaced a plastic bolt you would know of what I speak. If you want though I can send, I have dozens.
Dan Petchel
CarsincNJ.com
Targa top Restoration
Vintage parts
609 298 2277
carsinc@comcast.net
Old 06-19-2020, 12:42 PM
