Glove compartment light
these are the 3 positions for glove box light:
1) off
2) on
3) off / on when opening and closing glove box door.
my issue is that the #3 position does not work, the light will not come on when opening the glove box door.
Any ideas on why?
‘85 911
Old 06-01-2020, 07:34 PM
Formerly known as Syzygy
Canada Kev's Avatar
Bad/stuck switch?
Kevin
Old 06-01-2020, 09:10 PM
Banned but not out, yet..
RSBob's Avatar
Originally Posted by Canada Kev View Post
Bad/stuck switch?
Nailed it! Or improperly wired.
Old 06-01-2020, 09:17 PM
Switch wire unknowingly removed or cut when someone installed a radio? I’ve seen that one a few times.
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 06-01-2020, 10:11 PM
I corrected the crossed wires and the glove box button worked as it should, light is on when box is open off when box is closed...BUT!... only works when the light fixture is out of the dash..when I put the light fixture back up into place the glove box “button” did nothing... light stays on when door is closed. I have the light in the correct position... I know because like I said it works properly when the light fixture is hanging out of the dash. Ground problem? Thanks
Old 06-07-2020, 09:31 AM
Tags
glove box door , glove box light , interior lighting
